Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
One thing I noticed with the A380 is that it only seems to use the inboard thrust reversers while landing. I suspect it relates to FOD ingestion or perhaps damaging the runway. This is strange though, because the 747-8 (which also has a large wingspan and very large engines), does use all of its thrust reversers during landing. Does anyone have an official answer on why this is?
share|improve this question
up vote 12 down vote accepted
Why doesn't the A380 use its outboard thrust reversers?
Because it doesn't have (or need) any.
The A380 has reverse thrust on the inboard engines only. This saves weight and since the outboards are often way out over the edge of runways, decreases the risk of FOD.
From Airliners.net
The A380 apparently has 10 braked axles. It can stop from V1 on brakes alone with disks worn to minimum.
I've read that most airliners are allowed to take off even when all reverse-thrusters are inoperative. Most of the deceleration is handled by the brakes normally.
With the Airbus A380 weighing in fully loaded at 1,265,000 pounds, you might think stopping it within a reasonable distance after landing would require a Phalanx of Heavy-duty thrust reversers.
Truth be told, in the megaliner’s braking system, thrust reversers are the least critical components. Airliners are not required to have thrust reversers, and only the two inboard engines on the A380 are equipped with them. The decision not to install reversers on the A380’s two outboard engines saved weight and lowered the chances that those engines, which sometimes hang over runway edges, would be damaged by ingesting foreign objects.
The two reversers do help slow the A380—but not by much. In fact, unlike the thrust reversers on most airliners, including the Boeing 747 jumbo, they do not stop the aircraft in a shorter distance than brakes and spoilers alone. They do, however, take some of the strain off the brakes and are useful if water or snow makes the runway slippery.
From Airspace Magazine
share|improve this answer
Millions of man-hours and dollars are spent on duplicate, triplicate (or more) redundant heterogeneous systems on aircraft. See Perdue University, College of Engineering – RedGrittyBrick Jun 18 '14 at 14:06
@BrysonS.: Not really. All main gear axles are usually braked. The difference is in cooling of the brakes. Every aircraft has to be able to stop without reversers, because the probability of their failure is too high to rely on them, but it might be at the cost of overheating the brakes. A380 brakes have sufficiently good cooling that they deemed two reversers sufficient. – Jan Hudec Jun 18 '14 at 18:08
@Phil I second RedGrittyBrick's suggestion on making your comment a question. If you do, I'll provide an answer far longer than what I can get into a comment here. – Terry Jun 18 '14 at 20:14
" It can stop from V1 on brakes alone with disks worn to minimum." - All aircraft can do this, it's a certification requirement and (partly) used to determine the runway requirements. But it's really bad for the hardware. White-hot brakes can (and do) set tires on fire, and replacing half of your undercarriage every time the pilot tries to exit on Charlie instead of Delta gets rather expensive. – paul Jun 18 '14 at 21:23
@PhilPerry doesn't apply on takeoff because the jet blast is behind the engine, and it's accelerating away from the debris. Point your exhaust forward while slowing down, and you will at some point inhale any debris you kick up. Some small bizjets do use sideways "reversers" but they are more "thrust cancellers" as they do not slow the aircraft in any way. – paul Jun 18 '14 at 21:27
discard
