Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Since pitot static systems are open the outside, how does the system remain clear of water or other contaminants?
share|improve this question
up vote 13 down vote accepted
Though it's often omitted from diagrams, most pitot tubes have one or more drain holes connected to the pressure chamber, and are essentially "self-draining" (water doesn't make it into the lines):
Piper pitot blade - Drain on bottom Dynon pitot tube drain holes
In addition to drains on the pitot tube itself some aircraft have separate "drip chambers" and drains for the pitot (and occasionally static) system to remove condensation or rain that got past the drains (marked as 2 in the photo below):
PA-28 pitot/static drains
Regarding other contaminants, at altitude the air is generally pretty clean.
The biggest problem you'll have with contaminants in the pitot tube is usually bugs (either building a nest in the opening, or smacking into it in flight). Pitot covers can be used on the ground to prevent this (and they're also used when washing or painting aircraft to prevent water or paint from getting into the system). Often some tape serves the same purpose - but you need to be sure to remove the tape or cover before flying.
Someone is having a bad day...
share|improve this answer
+1. Nevertheless, it is possible for water to enter the system and cause problems. In these cases the system must be drained from a sump, sometimes by forcing air through the system in a maintenance shop. See stories here and here where this happened. – dvnrrs May 20 '14 at 16:49
@dvnrrs Yup - there have been cases where the drains in the system are inadequate - in those cases unless there's a pilot-accessible drain the system needs to be opened and drained by a qualified shop, and leak-checked when reassembled. – voretaq7 May 20 '14 at 16:52
And blocked tubes will cause havoc for the pilot not expecting it – ratchet freak May 20 '14 at 18:33
+1 for the bug! – CGCampbell May 20 '14 at 19:02
@CGCampbell That was one of the top 5 results for "bug in pitot tube" -- It was so hilarious I just couldn't resist! – voretaq7 May 20 '14 at 19:34
discard
