Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Looking at the paths of the same flight on two different days, I noticed they flew very different paths.
Short Path:1
YAY N184B TOPPS ENE PARCH1
Short Path
Long Path:1
NIBAX G462 TUMAK UL602 ORSOL UL602 DAVUS UL602 TASMI UL602 ITBIT UM860 KABAN UT334
INB UL852 UDROS L621 REVDA UP193 CND UP193 KARIL UL624 LABUK UY444 ELMEK UL726 OKG
UL984 NOSPA TOLVU UN857 GIMER UT300 EVX UT176 LGL UN491 KOKOS UN585 REGHI UN480
ETIKI NATD DOVEY LACKS BERGH L454 OWENZ CAMRN CAMRN4
Long Path
I asked a similar question in the past. This is what I want to know:
  • What are the reasons which can cause a commercial flight to change its path mid-route?
  • How it is planed and executed?
  • I am sure the captain is the final authority on this, but who else is informed?
1Route Source: FlightAware.
P.S.: I could not understand the routes at all.
share|improve this question
second final say is ATC, first say is submitting a flight plan – ratchet freak Apr 28 '14 at 19:43
up vote 9 down vote accepted
A flight plan is just that, a plan. A flight can deviate from its cleared route for many reasons, the most common of which are:
  • Weather
  • Traffic
  • Shortcuts
Weather reroutes are often initiated by the crew.
Center, N12345 request 15 right for weather
N12345 15 right approved for 100 nm, report direct XYZ.
Or they can be initiated by ATC
N12345, Atlanta, your arrival into EWR is in perpetual holding, I can re-route you over PA or NY or do you need to divert? state intentions.
Large scale re-routing for weather will occur when an organized line of convection impacts a major route. Even a short deviation for weather may result in an amended route if the controller has an alternate clearance he can put you on that works for you (being on a clearance and on-route is slightly less work for a controller than being on a carte-blanche deviation).
Traffic conflicts are usually short term vectors, but if you have an aircraft slowly overtaking you, you may be moved to a parallel route or have you altitude changed. These, like the weather example above, would result in amended clearances.
Shortcuts are often requested to cut corners or try to make up some time lost in a long taxi on the ground. These are usually crew initiated, but sometimes ATC will solicit them. Regardless of what route is submitted in a flight plan, ATC will generally clear you via a preferred routing. These routes aren't always the shortest distance between a departure and arrival and this is where shortcuts can be requested. Usually this just means skipping a fix or getting direct routing to a later fix in your clearance. The availability of shortcuts is a function of traffic, time of day, agreements between ATC sectors, what region you are in and what altitude you are at.
When you are on international flights, another issue you may run into is political and could result in some or all aircraft being routed to avoid certain airspace.
Lastly, your dispatcher may re-route you and ATC will clear you along a new route.
In all cases, whether deviation is pilot or controller initiated, both parties are in sync with what the airplane is doing, which will either be a vector or a new clearance. Your dispatcher will be notified of this change automatically via their dispatch software (which is likely fed data from both ACARS and the FAA).
share|improve this answer
Thanks Casey. I didn't completely get about shortcuts concept. If there existed a shortcut which the airplane will take in case of delay in taking off, why they didn't plan it initially? Why they choose to take a longer route when there is a shorter one available? – Farhan Apr 28 '14 at 21:11
About changes in path because of political reasons, can they happen on daily basis? Can country X tell country Y "hey, don't fly over us at FL380 tomorrow"? I know about TFRs, but can they affect at that high altitude also? – Farhan Apr 28 '14 at 21:15
@Farhan I edited in some more information regarding shortcuts. In short you can file the shortest route possible, but the ATC computer is going to spit out the route it wants you to fly, not necessarily the one you do. – casey Apr 28 '14 at 22:03
Can you please explain the political reason too and my question about that? Thanks. – Farhan Apr 30 '14 at 14:55
Can 9/11 explain the political reason required re-route? – vasin1987 Apr 30 '14 at 19:01
discard
