Take the 2-minute tour ×
I took a couple of pictures of various aircraft and I would like to know which aircraft I photographed. I have no idea, expect that all of them took off from ZRH and should be commercial airliners:
share|improve this question
Beautiful pictures :) –  flyingfisch Apr 26 at 14:18
Just wanted to point out that the plural of "aircraft" is "aircraft". :) –  egid Apr 27 at 15:39
add comment
up vote 9 down vote accepted
One of the simplest things you can do is to type in the registration into Google which will normally give you results of the type and history of the aircraft.
Otherwise, many airlines don't operate too many types of aircraft so a quick look on Wikipedia and looking through 'fleet' should show you which types it may be, from which elimination should be pretty quick.
The registration is normally visible on the back of the fuselage and under the wing, and the last two letters are (often) printed on the aircraft 'forehead' above the cockpit windows, the top of the tail and the nosegear doors.
Lufthansa
Aircraft from your photos:
  • Boeing 737
  • Airbus A320
  • RJ85
  • Airbus A320
  • Airbus A321
  • Fokker 100
share|improve this answer
Ok, but how do I know the registration? –  RoflcoptrException Apr 26 at 12:52
@RoflcoptrException That's the little code on the back of the aircraft fuselage :) (And the last two letters are displayed on the nosegear doors) –  MikeFoxtrot Apr 26 at 12:54
Cool, thanks a lot! –  RoflcoptrException Apr 26 at 13:01
@RoflcoptrException: Note also that you can determine the registration country of the aircraft from the code. If it starts with N it is USA, C is Canada, G is the UK, D is Germany, and so on. –  Eric Lippert Apr 26 at 16:32
And sometimes part of it is shown on the top of the vertical stabiliser as well, and/or on other places (e.g. KLM tends to put the last 2 letters over the windscreen rather than the nose gear bay doors). –  jwenting Apr 28 at 8:19
add comment
The accepted answer has good advice. I would add that a quick and easy way to make a guess at the manufacturer is to look at the ends of the wings. Notice how in the first picture the wings "bend up" at the end. This is highly characteristic of Boeing 737s; you can read about it here:
http://www.b737.org.uk/winglets.htm
By contrast, the "fence" style wing tip that you see in three of your photos is highly characteristic of Airbus.
See
http://en.wikipedia.org/wiki/Wingtip_device
for more information about why wings have unusual tips.
Blended winglets are no longer unique to Boeing. I've started seeing Airbus's "Sharklets" in the wild. –  egid Apr 26 at 17:58
add comment
discard
