Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've often noticed that planes flying on more or less the same track, headed in the same direction leaves different contrails. By different I mean how long they stay visible and the length of them. Why is this so? Is it weather related?
share|improve this question
they depends on the weather conditions, if the air is dryer they are shorter to non-existant – ratchet freak Apr 22 '14 at 9:34
Related: aviation.stackexchange.com/q/3089/95 – yankeekilo Apr 22 '14 at 11:44
Some areas of the country need more mind control drug than others. ๐Ÿ˜„ – Adam Davis Apr 22 '14 at 21:29
up vote 16 down vote accepted
It is a mixture of factors. All else being the same:
  • a contrail at a higher altitude will last longer (the lower temperature slows the sublimation of the ice cristals)
  • a contrail formed in air with higher humidity will be bigger and last longer (more water is being turned into ice)
If there is not enough (relative) humidity, the contrail will not form at all. See for example this image: enter image description here Image from NASA
The contrails start forming on the east, near the clouds where you have a higher humidity, and do not form on the west, where no cloud is present and you have higher temperature/lower humidity.
What you observe might be airplanes flying at different altitudes and thus encountering different humidity/temperature combinations, giving birth to contrails with different histories.
share|improve this answer
discard
