Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Yeah, it sounds like two questions, but I suspect the answers are very closely linked (or maybe even have the same answer.) I was told in this question that trainer planes are often designed to be stall or spin resistent. I was wondering how this is accomplished?
How does one make a wing resistant to stalls or spins? Or perhaps, more generally, how does one make a wing predictable and stable?
share|improve this question
up vote 10 down vote accepted
It's really two separate questions. In both cases the wing is not alone, it is the whole configuration, especially when it comes to spins.
A stall is unavoidable. At some point the airflow over the wing will start to separate, and if this flow separation is extensive enough to limit the increase in lift with increasing angle of attack (AoA), the wing stalls.
To make stall characteristics benign, the outer wing should still have mostly attached flow to enable the ailerons to correct roll angle. If the stall starts on one wingtip, causing a local loss of lift, the aircraft will roll uncontrollably. The downward movement of the wing tip during the rolling motion increases angle of attack further, thus making the stall unrecoverable. You achieve roll control by using washout at the wingtips and/or by using airfoils with a higher maximum AoA, eg. by using slats on the outer wing.
The second condition is a gradual flow separation, starting from the trailing edge. Old five-digit NACA airfoils had a nasty stall characteristic with flow separation starting from the leading edge, resulting in a sudden drop of lift. This is achieved by designing the upper surface with an appropriate chordwise pressure distribution. Then the loss of lift over AoA will be gradual, giving the pilot the opportunity to recover easily.
In all cases, the tail (or in canards the main wing) needs to remain in the attached flow regime to enable pitch control and pitch damping. In addition, the vertical position of the tail should be slightly lower than the wake from the separated flow, still close enough to have some turbulence hitting the elevator (so that the pilot feels the stall with the stick/yoke), but low enough that the airplane will not enter a deep stall (where the wing is fully separated and the tail in the wake of the wing, which reduces control authority to a point where the pilot cannot pitch down anymore).
Spinning needs a fuselage with some mass along the length. The rotation of this mass at a high AoA produces a pitch-up moment which is needed to stabilize the spin. The tail must be able to produce the remaining pitching moment and a yawing moment to stabilize the spin, but also to end it when the pilot so wishes. For this, it is important that the rudder is not in the wake of the horizontal tail. The deHavilland Tiger Moth has two aluminum strakes ahead of the empennage; without them a stall is unrecoverable because the rudder authority is not sufficient. To end a spin in the F-14, the all-flying tailplanes had to be pulled all the way to their minimum angle of -70°, so they would not obstruct the flow to the two rudders. Only when the pilots would pull, they could end the spin.
Just to be clear: Normally you need to push to end the spin. Especially in gliders with their relatively small rudders and large wing inertia, this will put most of the wing back into the normal flow region, and roll damping will stop the rotation. This ends the inertial pitch-up from the fuselage, and the aircraft can be recovered.
In more fuselage-dominated configurations, you end the spin by applying rudder against the spin direction. This reduces the rotation, reducing the inertial pitch-up and allowing the airplane to recover to normal AoAs.
Other than the stall, a spin is not always possible. Sometimes, especially at forward center-of-gravity locations, the pitch authority will not be sufficient to stabilize the spin. You can stall and apply rudder, but the airplane will only enter a spiral dive. Especially on jets the forward fuselage is a major factor in spins, because it produces a wake at high AoA which stabilizes the spin. Details in the shape of the fuselage will determine if the wake is sufficient to enable spins. This is a complex topic - sorry, but this scope makes it hard to get into more details.
share|improve this answer
There are several ways a small airplane can be designed to be resistant to stalls and spins. Both cases are somewhat similar in that they both involve cases where the aircraft's controls are rendered ineffective, and a stall can lead to a spin if not properly corrected. While a stall is certainly largely dependent on the aircraft's wing, both stalls and spins also depend on the whole aircraft's geometry.
There is some interesting information here about spins and stalls. Wikipedia also has a good article about spins. There are FAA requirements for single-engine planes in FAR 23.221.
In order to maintain control in a stall, devices like vortex generators can be installed upstream of the ailerons. If the air flow separates from the wing before the ailerons, the air is no longer flowing over the control surfaces, resulting in a loss of control. The vortex generators help the flow to remain attached past the ailerons, helping them to stay effective at high angles of attack.
Besides vortex generators, the wing itself can be designed for a similar effect. The inboard sections can be designed to stall before the outer sections, so the lift decreases but the outer sections will still provide lift and control.
The aircraft can also be designed such that the elevator does not have enough authority to fully stall the plane, or not any further than the ailerons will still have authority. The effect of the elevator will also depend on the airplane's center of gravity, which has a suggested range but is determined by the operator.
A spin is related to the geometry of the airplane, where the air flow past the wing "blanks" the tail surfaces. This geometry can be arranged such that it would be more difficult to create spin conditions. However, conventional aircraft designs tend to inherently be susceptible to this. Most aircraft are certified as "spin recoverable", meaning that the aircraft will spin, but the pilot should be able to stop a spin with the proper control inputs. Improving the plane's stall characteristics will also help prevent spins from happening.
Nice, very good answer. I do wonder, when a wing is fully stalled, will the vortex generators also aid in stall recovery? It stands to reason...but I thought I'd ask. – Jay Carr Apr 18 '14 at 17:17
Depends what you mean by "fully stalled." Of course the vortex generators are only effective up to a certain angle of attack, after which they won't matter as much. But increasing the controllable AOA will certainly help throughout at stall and recovery. – fooot Apr 18 '14 at 17:21
The control surfaces are still working, because the flow stays attached to the lower part. They are less effective, yes, but not ineffective. In bad designs the upper flow separation becomes so much worse with aileron deflection that the rudder authority is reversed, but such bad designs should be older than you and me together. – Peter Kämpf Apr 18 '14 at 17:33
One point to consider is that even if an elevator doesn't normally have enough authority to fully stall the plane in a steady state, the plane could still enter an accelerated stall by pulling back abruptly at high speeds. – Lnafziger Apr 18 '14 at 18:06
discard
