Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I was reading this question and I want to know what this term means.
land and hold short clearance
share|improve this question
also related aviation.stackexchange.com/questions/1967/… – falstro Apr 8 '14 at 12:50
up vote 15 down vote accepted
It means that you can land on the runway but must hold short (read: do not cross) before some point on the runway.
AIM 4-3-11 Pilot Responsibilities When Conducting Land and Hold Short Operations (LAHSO)
6. A pilot who accepts a LAHSO clearance should land and exit the runway at the first convenient taxiway (unless directed otherwise) before reaching the hold short point. Otherwise, the pilot must stop and hold at the hold short point.
This is generally issued for smaller planes that don't need the full runway and a crossing runway/taxiway is also being used.
As the pilot you have final say in accepting the clearance, if you feel you will be unable to hold short then you should reply "unable" and request full-length landing clearance.
[same link as above]
3. The pilot-in-command has the final authority to accept or decline any land and hold short clearance. The safety and operation of the aircraft remain the responsibility of the pilot. Pilots are expected to decline a LAHSO clearance if they determine it will compromise safety.
share|improve this answer
Nice answer. I might add two more points for completeness: A pilot with a LAHSO clearance may still go around per AIM 4-3-11(b)(5); and student pilots should not accept a LAHSO clearance per AIM 4-3-11(b)(2). Of course, a pilot should read the AIM section completely before accepting a LAHSO. – dvnrrs Apr 8 '14 at 13:04
For those that may be reading this in the future, the FAA unfortunately killed their HTML versions of the FAR/AIM, so the links in the above comment are dead. The FAA now has a PDF version of the AIM and faraim.org now publishes an HTML version. – reirab Jul 24 '15 at 14:27
discard
