Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
After a discussion in chat about control surface locks I was wondering why they need to be locked in the first place.
Why do they need to be locked?
What is the best position to lock them in? up, down, neutral.
share|improve this question
Which control surfaces exactly? There are quite a number of´em, depending on the actual aircraft. – yankeekilo Apr 5 '14 at 18:53
@yankeekilo the discussion started about the elevators, but the answer can take all into account. – ratchet freak Apr 5 '14 at 18:55
up vote 14 down vote accepted
Other folks have already addressed why we want to lock the flight controls when we leave the aircraft - "to prevent damage from gusts of wind", and "to keep the plane from doing interesting things in a strong breeze".
To the question of the "best" position to lock controls in, for light aircraft the general consensus is that the rudder and ailerons should be locked in the neutral position - In this position any wind blowing over the wings will cause them to lift uniformly, putting tension on the tiedown ropes holding the aircraft to the ground. (If the ailerons are locked at an angle one wing will generate more lift than the other, allowing one of the tiedown ropes to go slack.)
Elevators are a subject of a little more nuance and debate: It's generally considered best to lock the elevator in the "nose down" position (because any gusts of wind over the tail will push the nose down, rather than encouraging the nose to lift, this also means that those gusts will apply tension to a tie-down rope located at the tail rather than causing it to go slack).
On some aircraft locking the elevator in the nose-down (or nose-up) position opens up spaces that birds may try to nest in (for example, check out the tail of this Grumman) - some pilots prefer to lock the elevator of these aircraft in the neutral position to discourage avian visitors.
Generally it's better to lock the controls than leave them unlocked to bang around in the wind, so on some light aircraft not equipped with control locks pilots use the seatbelt to hold the controls in place. This often results in a "sub-optimal" control position (elevator fully nose-up, ailerons full-deflection left or right), but because the wind speed at which control surfaces may bang against their stops is usually lower than the speed at which the aerodynamically unfavorable control positions will substantially affect the aircraft this is a "lesser of two evils" approach.
share|improve this answer
In the small planes I fly, it is called a "Gust Lock", and consists of a small metal bar that fixes the yoke in position, so that the yoke cannot move (left/right, or forward/back), and by association, the ailerons and elevator cannot move either.
As the name implies, this is for dealing with Gusts of wind... a sudden bit of wind over an unlocked surface can move the surface to its extreme position until it hits a mechanical stop. If this happens repeatedly, say, over a stormy night, the repeated banging into a mechanical stop can create wear and tear on the surface, the control cables, or the yoke in the cockpit.
There are also external gust locks (typically found on rudders which can't be locked by freezing the position of the yoke). – voretaq7 Apr 5 '14 at 20:50
Good answer. Another concern, especially for larger planes with more ground crew operations, is pinch hazards. A moving control surface on an airliner can easily chop off a finger or give someone a nice concussion. – dvnrrs Apr 5 '14 at 22:15
Just remember to unlock them BEFORE you take off darwinawards.com/darwin/darwin1998-09.html – NobodySpecial Apr 6 '14 at 4:00
@NobodySpecial: Another example: nationalmuseum.af.mil/factsheets/factsheet.asp?id=2478 – Fred Larson Apr 7 '14 at 14:41
For gliders (probably other aircraft as well), there are two reasons to fix ailerons, elevator (and rudder) positions:
  1. You want to avoid uncontrolled (potentially damaging) sudden movements caused by (repeated) wind gusts.
  2. If you choose or allow unlucky positions/configurations, your plane might exhibit unwanted positional initiative (e.g. an aileron might motivate one wing to lift unexpectedly, hitting heads, tarmac or other obstacles). In mildly gusty conditions, wings are often temporarily fixed by additional weights (usually old tires or similar) to avoid that, too. As mentioned in the comments, this is not sufficient for anything more than average winds.
It should be a bit more than just "old tires" (though old tires make great markers so you know where the anchor points are) - The FAA has a great advisory circular on tiedowns & anchors that talks about what it takes to hold a plane down in strong winds. – voretaq7 Apr 5 '14 at 20:25
@voretaq7 Correct, the tires are just good for casual use in average conditions. If it gets really windy, you need a decent tethering - we use mostly screw anchors, e.g. overnight on holidays. Great link! – yankeekilo Apr 5 '14 at 21:20
“unwanted positional initiative” is a pretty sweet phrase ;) – Peter Apr 7 '14 at 2:36
@Peter "bad attitude" might have worked as well :-) – yankeekilo Apr 7 '14 at 5:11
discard
