Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have recently been using a mobile app to track flights, which is really cool. I live in the rural heartland of America, so it's an event for me to see an A380 actually flying.
Every once in a while, a squawk 7700 alert will come up, which I understand is the emergency transponder code. There are more, such as 7600 and 7500, which I find are less common.
My question is, is there a way to do some post-mortem followup as to why the aircraft squawked the code? Is this public information that can be found by some agency such as the NTSB?
share|improve this question
The Aviation Herald publishes some of these events. The FAA (and corresponding agencies) publish periodic summaries of these events as well (if they are reported). – fooot Apr 4 '14 at 15:35
That would actually be a really good answer :) – Styler Apr 4 '14 at 15:37
up vote 12 down vote accepted
This FAA webpage has a list of the various transponder codes and what they are used for, which will give you an idea of what the problem is. Unless there is an actual aircraft incident or accident which requires the FAA to investigate though, you won't be able to find a record of it. In fact, pilots aren't even required to file a report unless requested, and those don't go into a public database.
For actual incidents or accidents, you can look at the NTSB Accident Database & Synopses.
For pilot reports to the NASA ASRS self-reporting safety system, you can search their database. If the pilot filed a report then you will see it show up there.
Commonly used emergency codes are:
  • 7500 - Hijack Code
  • 7600 - Loss of Radio Communications Code
  • 7700 - Emergency Code
Also, some countries use the code 7000 for VFR traffic (which is not an emergency code), but the US uses 1200 instead.
share|improve this answer
12
I have seen a mnemonic for the emergency codes in the past. I do not recall where I saw it, and I don't know how common it is, but I found it helpful in remembering them: "75, taken alive; 76, caught a glitch; 77, going to heaven". – David Conrad Apr 4 '14 at 20:35
I know "75 - man with knife" – Philipp Feb 17 '15 at 0:12
An emergency requiring a Service Difficulty Report (SDR), generated by owner self-reporting or investigation results, is reported by tail number. If you know the number, or other equipment identifying attribute, you can search here.
For reports filed less than a week to 6 months after incident, FAA packages are published within a week. You can find these on this FAA data source.
I am not sure this answer the question. where are the squawk codes? – Federico Apr 12 '15 at 7:08
I think it answers the question. He's saying to find out why, write down the tail number then search some time later. – kevin Apr 12 '15 at 7:33
protected by Community Jul 13 '15 at 2:34
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
