Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
How does the Earth's eastward motion figure into the tracks proposed by Inmarsat data etc?
share|improve this question
up vote 8 down vote accepted
Not significantly. The aircraft flies in the air. The air moves over the earth and takes the plane with it. Of course wind is affected by the rotation of the earth, but there is little direct effect of Earth's rotation on the motion of the plane. The coriolis forces have a negligible effect on the aircraft's track.
The Inmarsat satellite used is geostationary, so it rotates as fast around the earth as the earth around its axis. The nett effect is zero.
share|improve this answer
Plus, depending on the map used, a great circle / straight course may render as an arc. – yankeekilo Apr 3 '14 at 5:57
@yankeekilo yes indeed. Plus that the initial arcs published by Inmarsat were arcs of constant distance from the satellite, not the track of the aircraft. – DeltaLima Apr 3 '14 at 5:58
Aren't all weather systems due to coriolis forces acting on the air? Since the plane is moving through the air, it would have same, significant, effect on the plane, wouldn't it? You could of course cut down the complexity and say the aircraft is pushed by the wind, same thing :) – falstro Apr 3 '14 at 6:16
@roe no, not all weather systems. – Federico Apr 3 '14 at 7:08
@roe as you wish, but you still do not consider that the aircraft is pushed by the engines and that if a course is set, any deviation due to wind will be corrected. – Federico Apr 3 '14 at 7:40
The earth's rotation affects aircraft in much the same way as it affects you and I on the surface. From that perspective we are all being carried along at around 1000 MPH. Since the atmosphere is a very very very thin layer of gas above the surface, it pretty much rotates with the surface. You'll notice the oceans don't slosh across the continents every 24 hours too.
As Federico pointed out, following a constant magnetic heading from a fixed point on the surface will not be affected by the speed of rotation of the planet. Your navigational frame of reference is earth-centric not solar-centric (say).
"You'll notice the oceans don't slosh across the continents every 24 hours too." They do it every 12.5 hours! (But only a little bit.) – David Richerby Apr 3 '14 at 12:47
The problem with this question is that there is a seriously wrong assumption behind: you are assuming that the airplane drifts along a course, like a curling stone after being launched, and is affected by all kind of environmental disturbances.
The thing is that the airplane has engines and control surfaces, in the case in question even an autopilot: if a certain course/track is selected, the plane will follow it, eventual wind will simply change the attitude at which the plane is flying (yaw for side component, pitch for front component), not the ground track. Unless you are in sidewinds/headwinds that exceed the top airspeed of the aircraft, but that was not likely the case.
If the side winds exceed the top airspeed of the aircraft, deviating from the ground track is the least of your problems, I believe ;-) – Jan Dvorak Apr 3 '14 at 13:41
@JanDvorak indeed :D – Federico Apr 3 '14 at 14:09
Ah, so that's what happened when I tried flying my Cessna through a tornado funnel! – Phil Perry Apr 3 '14 at 14:36
discard
