Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I was reading some forum about funny ATC communications and one commentary was
GXXXX: Request status of danger areas X1, 2 and 4
<Pause>
London info: I don't recognise area number x124
GXXXX: My mistake I meant areas x1, x2 and X4
London info (female): Sorry, just had a blonde moment here
(assume she was new and didn't know the non appologising [sic] rule)
(source)
when referring to some thing the ATC said, apologising for not understanding some non-formal phraseology.
What is that rule ?
share|improve this question
12
unnecessary apologies just clutter the frequency – ratchet freak Apr 2 '14 at 18:58
A link to the forum and/or quote of the exact words spoken might improve your chances of getting a good answer. (But I think @ratchetfreak is right.) – dvnrrs Apr 2 '14 at 19:08
yes, edit was right, thanks @ratchet ! – woliveirajr Apr 2 '14 at 19:26
up vote 14 down vote accepted
I suspect there is no such rule. I looked at a few online sources - none mention the word apology (or variants).
ATC communication is expected to be short and follow a standard set of stock phrase forms.
Anything outside that is discouraged unless necessary to clarify instructions etc.
FAA
An FAA document "Radio Communications Phraseology and Techniques" says
Brevity is important, and contacts should be kept as brief as possible,
So any communication that doesn't follow one of the standard patterns is discouraged. It continues.
but controllers must know what you want to do before they can properly carry out their control duties. And you, the pilot, must know exactly what the controller wants you to do. Since concise phraseology may not always be adequate, use whatever words are necessary to get your message across.
ICAO
An ICAO document "ICAO Standard Phraseology A Quick Reference Guide for Commercial Air Transport Pilots" says
Phraseology has evolved over time and has been carefully developed to provide maximum clarity and brevity in communications while ensuring that phrases are unambiguous.
Again the emphasis is on brevity and standard phraseology. It also continues ina similar way to the FAA document.
However, while standard phraseology is available to cover most routine situations, not every conceivable scenario will be catered for and RTF users should be prepared to use plain language when necessary following the principle of keeping phrases clear and concise.
Other
For non-pilot rubberneckers like me, a good intro to pilot-ATC communication is a "Say Again" blog post or Two by Don Brown.
I remember one time when I was a young controller and working a slow, high-altitude sector. I was bored so I got into a conversation with a pilot about something or other. All of a sudden I noticed this F-15 was in a big turn.
 "Peach two one, Atlanta Center, where you goin'?"
 "Atlanta Center, Peach two one is declaring an emergency,
        we've lost an engine and are returning to Dobbins."
He couldn't get on the frequency because I was having a conversation.
share|improve this answer
Wow, that F-15 pilot was having a really bad day. Not only did he lose an engine, but he drew a mission callsign like "Peach." ;) – dvnrrs Apr 2 '14 at 21:38
@dvnrrs yeah i know, and on top of that the atc almost didn't hear him! – flyingfisch Apr 2 '14 at 22:25
@dvnrrs The official state nickname or Georgia is "The Peach State" so it would be unsurprising if, say, the Georgia Air National Guard used "Peach NNN" as a callsign. – David Richerby Apr 2 '14 at 23:28
@flyingfisch the military guys have the additional problem of being stepped on by us civvies because we can't hear them transmitting on the UHF frequency (but we can hear the ATC responses). – casey Apr 3 '14 at 1:30
@casey interesting, didn't know they transmitted on different frequencies than civvies – flyingfisch Apr 3 '14 at 13:09
As far as I know, this is not an official rule, but I have heard about it in the past.
I think the 'rule' has its background in two principles:
Firstly, you keep communications efficient and short. Don't block the frequency unnecessary. Some countries have guidance in their ATC communication handbooks that discourage exchange of courtesies. Apologizing could be categorized as such. For example: in the UK CAA has the following text in their CAP 413 Radiotelephony manual:
Avoid excessive use of courtesies and entering into non-operational conversations
Secondly, you don't apologise for asking clarification on the frequency. It implies that you made a mistake. Making sure that the communication is clearly understood by both sides is an essential safety requirement and therefore asking clarification should never be apologised for because it is the only right thing to do when in doubt.
In the context of the eternal pissing contest between pilots and controllers the above is sometimes reduced to following rules:
  1. Never apologize on the frequency
  2. Never call a pilot 'Sir'
It will make THEM feel superior.
In the eternal pissing contest between pilots and controllers the pilots pretty much always win (the worst a controller can do is yell and maybe burden you with some paperwork – voretaq7 Apr 3 '14 at 6:22
Another reason not to call a pilot 'Sir' is you might be wrong. I've been called "Ma'am" on the radio a time or two. I'm a tenor, thank you very much, not an alto. – Fred Larson Apr 3 '14 at 17:16
discard
