Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've heard that in a lot of instances a jet that is making an emergency landing is required to dump excess fuel. In a lot of instances this would make a lot of sense. For example, if the gear cannot be lowered and the plane must land on its belly. The last thing you want is a hundred tons of jet fuel involved.
But, I have to assume there are also emergencies where a plane isn't required to dump its fuel. I just am not sure what they would be?
So, my question is: When are aircraft required to dump fuel before landing (or, at very least, when is it advisable to dump fuel before landing).
Bonus points:
  • How much fuel does an aircraft retain after an emergency dump? I'm assuming they don't dump it all or they would have no fuel to maneuver with.
  • Examples would be great.
share|improve this question
My understanding is the major consideration is usually weight - large aircraft typically take off at a weight higher than their maximum landing weight (with the intent to burn off the excess weight in fuel during transit). If an emergency arises they may not have burned off enough fuel, and will have to dump the excess. – voretaq7 Mar 28 '14 at 19:27
up vote 34 down vote accepted
For many medium and large sized jets the maximum gross takeoff weight is higher than the maximum landing weight. If the airplane has an emergency that requires an air return or other landing in the early part of flight, it is very likely overweight for landing. The plane has 3 options at this point:
  1. Land overweight
  2. Dump fuel (if able)
  3. Fly around at low altitude and high power to burn fuel
For some airplanes, option 2 is not available. This includes airplanes that are not equipped to dump fuel (not all airplanes have this capability or have the capability under MEL) or are not approved to dump fuel at their current location and altitude. For these airplanes, only option 1 and 3 are available.
The choice between option 1 and 2/3 comes down to what kind of emergency it is. If you have to be on the ground now, you won't care about being overweight, and will just put it down. If you have time and landing now isn't a priority, then you would choose to dump or burn fuel.
If an airplane chooses to dump, they will generally choose one of two values of remaining fuel:
  1. fuel such that they land at the maximum landing weight
  2. absolute minimum safe fuel to land
This choice comes down to how likely the landing will end in an accident. If you are sure the landing will be a non-event (e.g. air return for anti-ice failure) then you'll likely just dump until landing wont be overweight. Conversely, if you have a control issue or something that may end badly, you want minimum fuel to lessen the potential for fire. In these cases the ARFF crew will spray the runway with foam to assist in reducing the fire potential.
share|improve this answer
So it's all just up to the pilot? Or are there cases where there are guidelines that must be followed even if the immediate usefulness is not apparent? – Jay Carr Mar 28 '14 at 19:43
The pilot is the final authority on all aspects of operating the airplane, including the decision to dump fuel. The suggestion to dump fuel for a specific scenario is probably suggested in the QRH for whatever problem the airplane is experiencing. – casey Mar 28 '14 at 19:45
It is no longer advisable to foam the runway in fear of running out of foam if the actual fire occur – vasin1987 Mar 29 '14 at 22:48
The primary reason is to reduce the weight of an aircraft. Aircraft are designed to land at a maximum weight lower than their maximum weight. In order to be under that maximum landing weight, they must either burn that fuel during flight or dump it.
There is no requirement for them to dump fuel. This decision is up to the pilot. They may choose to land the aircraft "overweight", meaning over the maximum landing weight. In this case the aircraft will have to undergo an inspection to ensure that nothing was damaged. On some aircraft, an inspection is only required if the touchdown acceleration was over a certain amount (like 1.7G).
Dumping fuel will generally be an issue with a plane that has taken off for a long flight and has to divert for some issue. The pilot must decide how urgent the emergency is. If it is an urgent problem, such as engine failure, medical emergency, hydraulic issues, or fire, their priority is to land ASAP regardless of weight. They may dump fuel while headed to a diversion airport if they can.
If the emergency is not as urgent, the pilot may decide that they do not want to continue the flight, especially if it involves long stretches over water without diversion airports. In this case they can hold somewhere near a diversion airport to burn off or dump fuel until they are comfortable with their landing weight.
For example, the 777-200ER can take off at 656,000 lb, but maximum landing weight is 470,000 lb. This means they could have to dump 150,000 lb of fuel if they encounter an issue at the beginning of a long flight.
The amount they leave after dumping will be up to the pilot. For serious gear issues, they may want to be as light as possible and only leave a minimum amount of fuel in the tanks (on a 737, this is about 4,000 lb). For other instances, they may be satisfied with the maximum landing weight and not want to spend any more time dumping or burning fuel. No pilot wants to dump a bunch of fuel and then end up needing it later.
(+1) Note that "an issue" can be an external one, e.g. the closing of US air space on 9/11. (On an AMS-BOS flight soon after take-off.) – Keep these mind Mar 28 '14 at 19:56
In reference to how much fuel is retained, in the 747-100 and -200 aircraft it was not possible to run yourself out of fuel by dumping. There were stand pipes in the the system that prevented that. A common call to the flight engineer in the simulator for certain emergencies was to "dump down to the stand pipes." Offhand I don't remember how much fuel was left when that was done.
The most fuel I ever dumped to get down to max landing weight (635,000 lbs as I remember) was around 100,000 lbs. We did it at 4,000 feet over the ocean off Lima, Peru after an engine blew (it literally disintegrated inside) on takeoff. As I remember, we believed that dumped fuel evaporates in 2 to 3 thousand feet of fall, so we did not believe it would reach the water. Not that that was any consideration at the moment.
I was wondering if fuel did that (evaporate) in its fall to earth. I guess doing it over a non-populated area is just for safety precaution then. – Jeff Bridgman Aug 14 '14 at 12:51
@JeffBridgman My guess is that the 2 to 3 thousand feet is a general figure. At Lima, it's hot and dry. If it were cold and damp, I would expect it to take longer; how much I do not know. – Terry Aug 14 '14 at 16:44
The reason they dump fuel is to keep the landing gear intact during the landing. A plane at max takeoff weight will not be kind to its gear. Max takeoff weight has to be equal or higher is also higher than max landing weight. A plane where max takeoff weight is within 5% of max landing weight doesn't need to be able to dump fuel.
When there isn't a designated fuel dumping site (typically a nearby lake or ocean) or the plane can't make it there to dump fuel, they will instead circle around until the fuel level has dropped sufficiently. This is not possible when the emergency is of the kind that needs to be on the ground NOW.
A recent incident that had a fuel dump is Air France B773. Another incident where they couldn't dump fuel is Delta B763.
Thanks for the examples @ratchetfreak, always very instructive. – Jay Carr Mar 28 '14 at 19:37
10 or 20 years ago there was a plane taking off out of LGA or JFK that immediately had an emergency and dumped a lot of fuel over Queens or Brooklyn. No fire on the ground, but some homes were literally soaked and suffered damage to asphalt roofs (I would imagine street and driveway damage too). The plane landed safely. – Phil Perry Mar 28 '14 at 22:15
SwissAir 111 was circling near Halifax when it went down. Was this to burn off fuel? If so, were they unable to dump for some reason? – Phil Perry Mar 28 '14 at 22:17
@PhilPerry Yes Swiss Air 111 was dumping fuel when it crashed. With hindsight, that was one of the cases where they should have just got the plane onto the ground ASAP, even if it meant landing overweight. – David Richerby Mar 29 '14 at 0:43
@ratchetfreak Yeah. If they'd had the benefit of hindsight, they'd have just stayed on the ground in the first place. – David Richerby Mar 29 '14 at 1:01
Having spent 3 days with one of the investigators of the Swiss Air 111 flight during an international safety seminar, he said the dump was unnecessary as that bird was certified to land at its current weight when an emergency was declared. That very basic mistake cost all lives, as had he flown direct to land, he would have been on the ground before the fire was big enough to impact the cockpit. Both pilots had donned O2 masks. The fire burned through the copilots oxygen hose and turned it into a blow torch to the side of his head before they hit the water. This bird hit the water at an angle and speed which caused extreme water pressure to be forced into the fuselage. Pressures were so great, the water entered passengers bodies orifices and many had the top of their heads explode. He said it was a gruesome job for the recovery workers.
This is an interesting insight, but it doesn't really answer the question of when aircraft should dump fuel – Pondlife Feb 8 '15 at 21:07
discard
