Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Does CFIT apply in case of a plane (not an seaplane) failing a "landing" emergency in the open sea?
share|improve this question
up vote 9 down vote accepted
Boeing defines it in the following way:
Controlled flight into terrain (CFIT) describes an accident in which a flight crew unintentionally flies an airplane into the ground, a mountain, water or an obstacle.
Since it's not unintentional, it's better described as forced landing or in your case, ditching.
share|improve this answer
"Controlled" may also imply there was nothing wrong with the plane. – ChrisW Mar 25 '14 at 13:50
I think it implies that anything wrong with the plane didn't cause the impact. A multi-engine plane with a single engine failure (normally very survivable) but which then flew into the ground while under control would be CFIT/ – DJClayworth Mar 25 '14 at 21:38
Controlled flight into terrain means that the aircraft is under positive control, that is it's within its flight envelope and is being actively managed, however it's course brings it unintentionally into contact with terrain. A aircraft flying into the side of a mountain is controlled flight into terrain. An aircraft ditching, successful or not, is an intentional action so doesn't qualify.
discard
