What are the factors a pilot needs to consider before preparing for the steep approach?
How is steep approach combined with auto land feature.
  • $\begingroup$ This is a very broad question. Most aircraft require no certification for performing a steep approach. Airport requirements and pilot considerations vary widely with the situation. What industry sector are you considering in your question? $\endgroup$
    – J W
    Apr 6, 2016 at 11:34
    $\begingroup$ Usually a steep approach means they are avoiding an obstacle or have been asked by ATC to "make it short". A steep approach ends in a normal landing, if you are hitting the ground any harder than you do normally then you are performing the technique wrong. Speed can be managed in the approach so you are steep, but not fast, and it ends in a flare/touchdown just like any other landing. There are no certification requirements, but some aircraft are prohibited from slips or slips in certain configurations (like with full flaps). $\endgroup$
    – Ron Beyer
    Apr 6, 2016 at 12:35
    $\begingroup$ Related: aviation.stackexchange.com/questions/21956/… $\endgroup$
    Apr 6, 2016 at 12:56
    $\begingroup$ Somewhat related tactical penetration descent $\endgroup$
    – TomMcW
    Apr 6, 2016 at 16:15
    $\begingroup$ The three questions are rather loosely related, which is bad format for this site. Voting to close as too broad. $\endgroup$
    Apr 6, 2016 at 17:50
