Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
In this image of the Grumman X-29, there is an 'arm' just above the exhaust nozzle leading forward and, apparently, attached to the right side of the fuselage. What is this and what is it for? I realize this is an experimental aircraft, but it doesn't look like sensors (like the probe off the nose), it looks more like a structure for lifting the plane.
https://upload.wikimedia.org/wikipedia/commons/1/10/X-29_at_High_Angle_of_Attack_with_Smoke_Generators.jpg Source: Wikipedia X-29 Article
share|improve this question
Similar system on a YF-22: What is this red canister on the tail of the YF-22? – mins Apr 4 at 7:45
up vote 21 down vote accepted
Two X-29's were built, and the only difference between the two is that #2 has an externally mounted spin recovery chute attached to the tail. That is what you are seeing in this picture. The chute is packed in the tube structure and the "arms" are structural to distribute load.
Source
The only significant difference between the two aircraft was an emergency spin chute deployment system mounted at the base of the rudder on aircraft No. 2.
Here is a video of the chute deployed
And here are more details from NASA on the chute system
The reason that #2 needed this and #1 did not is that #2 was going to be conducting experiments at up to 67° angle of attack, where entering a spin was much more likely. #1's AOA was limited to about 21° and was considered the "phase-1" flight dynamics platform, while #2 was the "phase-2" platform.
share|improve this answer
To some extent, I was right, it is an arm for lifting the plane. by its chute, right out of a spin... :) – FreeMan Mar 12 at 0:57
discard
