Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am unsure of how to operate within this area (red dashed line) without connection to ATC. It appears to come off of class D airspace.
Can anyone provide an explanation of what this area is and how to operate within it?
share|improve this question
up vote 8 down vote accepted
Its an area of Class-E airspace used for Instrument Approach Procedures.
From The Pilot Handbook, Chapter 14, Airspace:
Class D airspace is generally airspace from the surface to 2,500 feet above the airport elevation (charted in MSL) surrounding those airports that have an operational control tower. The configuration of each Class D airspace area is individually tailored and when instrument procedures are published, the airspace is normally designed to contain the procedures. Arrival extensions for instrument approach procedures (IAPs) may be Class D or Class E airspace. Unless otherwise authorized, each aircraft must establish two-way radio communications with the ATC facility providing air traffic services prior to entering the airspace and thereafter maintain those communications while in the airspace.
(Emphasis Mine)
Also from that handbook, the procedures for operating in Class-E:
If the airspace is not Class A, B, C, or D, and is controlled airspace, then it is Class E airspace. Class E airspace extends upward from either the surface or a designated altitude to the overlying or adjacent controlled airspace. When designated as a surface area, the airspace is configured to contain all instrument procedures. Also in this class are federal airways, airspace beginning at either 700 or 1,200 feet above ground level (AGL) used to transition to and from the terminal or en route environment, and en route domestic and offshore airspace areas designated below 18,000 feet MSL. Unless designated at a lower altitude, Class E airspace begins at 14,500 MSL over the United States, including that airspace overlying the waters within 12 NM of the coast of the 48 contiguous states and Alaska, up to but not including 18,000 feet MSL, and the airspace above FL 600.
So basically class-E rules apply, but be aware you are operating in an Instrument Approach Procedure area.
share|improve this answer
Ah ha. Makes sense now. Thanks! – Yogwhatup Mar 11 at 15:24
The area inside those lines is class E from the surface.
discard
