Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
The airspeed indicator has a red marking that means: "never exceed this speed" ($V_{NE}$, around 160 KIAS). Why can't you exceed that speed?
share|improve this question
up vote 34 down vote accepted
You can, but you have to live with the consequences. There are several things that can happen:
  • Depending on the vertical gusts ahead, you might not even get close to v$_{NE}$. There is another speed limit for gusty weather called v$_B$, and exceeding this will run the risk of overstressing the wing structure. Going above v$_B$ will overstress the wings in a gust of more than 50 ft/s, and more than 25 ft/s when flying above v$_D$. The exact values can be found in the flight envelope diagram of the flight manual.
  • On a calm day, you can fly v$_{NE}$ and even a little faster, but once you fly fast enough, flutter will become very likely. Note that flutter needs some initial excitation, so you might fly well into the flutter speed range before flutter occurs. When it does, control surfaces will be ripped from their fittings which will make the aircraft pitch up. At that point the wings will break off.
  • The engine on a C 172 is not powerful enough to sustain level flight at v$_{NE}$. You need to dive the aircraft, which requires some altitude. Maintaining the speed will mean that you dive into the ground, so you need to pull out of the dive in time.
  • On really fast aircraft the pitch trim will get more nose-heavy when the aircraft approaches the speed of sound. You don't run that risk in a C 172, but faster aircraft found themselves locked into a dive which they could not end.
share|improve this answer
Note that for the C172, the published Vtap is probably more relevant than Vb (which I don't believe is published in the AFM). – Jonathan Walters Mar 5 at 17:01
11
Or as it may be, not live with the consequences :-) – jamesqf Mar 5 at 17:35
At that point the wings will break off. I hear from time to time about things that can make the wings break off, but then to the contrary I hear a lot about how the wings can't come off under anything but the most extreme circumstances, and stress tests where they show the wings buckled at a very large angle before something fails.. – Michael Mar 5 at 20:48
@Michael: Fly fast enough and everything will come off. Dynamic pressure is the thing to watch here: If it is high enough, even small angle changes will unleash immense forces. – Peter Kämpf Mar 5 at 20:52
You can exceed the never exceed speed $V_{NE}$, but doing so will most likely result in damage to the structure. From FAA handbook of pilot knowledge:
$V_{NE}$ —the speed which should never be exceeded. If flight is attempted above this speed, structural damage or structural failure may result.
Speaking of the FAA — if you exceed V_NE, then your airworthiness certification becomes void. – 200_success Mar 6 at 3:11
@200_success This is only a concern if you live through the experience. – Michael Hampton Mar 7 at 8:52
@MichaelHampton Presumably there is some safety margin built into the limit. – 200_success Mar 7 at 8:55
Because above that airspeed, the airframe is increasingly likely to fail.
Failure would likely start with control surfaces like the ailerons, elevator and flaps, then the wings and tail are likely to separate, resulting in total catastrophic failure.
Think of $V_{NE}$ as the speed at or beyond which the structural integrity of the airframe is not guaranteed.
In other words, parts of the airframe - which is critical for controlled flight cannot be guaranteed to perform as designed.
As stated in another response the stock engine in a C172 isn't powerful enough to sustain Vne in horizontal flight. Establishment of the various speeds is part of the aircraft certification process and usually includes a safety margin of 10 to 15 percent and there are many factors that go into determining these numbers. For example, I have a Beachcraft Baron and one of the important speeds is Vr or V Rotate. It's not that the aircraft cannot take off at a slower speed it's just that if you have a critical engine failure at takeoff power and a slower speed you don't have enough control authority to compensate. There are many factors that go into determining these numbers and structural integrity is just one of them.
This doesn't directly answer the question and is better off as a comment. – Porcupine911 Mar 8 at 5:19
The answer depends on how much you exceed V_ne. I do not have the information for this particular aircraft in front of me, so I can not say what will happen at a specific airspeed. Cessna spent a lot of money and time on engineering and flight testing to come up with the maximum airspeed (V_ne). There is a safety factor built in to this calculated and tested speed. One situation is flying level at a high altitude, then go in to a steep dive. This may cause an overspeed condition. One of the first problems as a result of overspeed, will start out as a vibration of control surfaces and controls. The chance for loss of control by the pilot due to mechanical failure or metal fatigue will increase exponentially, as does the airspeed. The C172 has airfoil designs meant for low speed. Depending on the exact plane and loading this could differ slightly, but the stall speed is 49 KIAS.
With its straight, high lift wing structure, the airfoil may actually completely loose its lift at a very high airspeed. As the airspeed increases, farther above the V_ne, the craft will basically start to tear apart and disintegrate.
discard
