Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
If I've done my training say 85% in a C152 and 15% in a C172, then upon my earning my PPL, what am I allowed to fly legally? I assume the 152, but not sure about the 172. Is this indicated somehow in my logbook? When is a separate check out required for a new airplane and assuming the same type (i.e., SEL, fixed gear, fixed pitch prop, non pressurized, etc.), what would this typically entail? Is this an FAA requirement or a liability requirement for clubs, etc.?
share|improve this question
up vote 9 down vote accepted
There are two aspects here, one what is required legally and then what may be required locally.
From a legal standpoint (in your case) the basic PPL will allow you to fly single engine, fixed pitch prop, under 200HP, fixed gear aircraft. If you want to go over 200 HP you will need a High Performance check out and log book endorsement. For a constant speed prop/folding gear/movable flap (all 3 are required to require this endorsement) plane you will need a complex endorsement in your log book. You may want to fly something like a Piper Cub which will require a tail wheel endorsement. If you are lucky enough (and have the funding to do so) you may find your self in a small pressurized single (or twin) like the Piper Meridian or TBM 900 these planes will require a high altitude checkout as well. AOPA has a nice summary of the endorsements here. If you want the full FAA FAR regs you can find them here.
Now as for a club or school that depends on a variety of factors including their insurance and their personal limits. I'll offer some personal experience which seems to be pretty par for the course. The flight school I fly from requires a checkout in type from every new renter before you can fly it even if you have a PPL and the proper endorsements. They don't have an official amount of time but it usually takes about an hour with an instructor. The former flight school I was at had the same deal with the exception of their Saratoga which they also required an instrument rating (along with their checkout).
My buddy's flight club is somewhat similar. They require a check out in their Archer and Dakota to fly solo. They also have a Lance which they require 25 hours time in type and a 5 hour check out in the plane.
As for your log book you should be logging the full type of aircraft for every flight. For example when I fly the Warrior I make sure to note PA-28-161 and the Archer I fly is noted as PA-28-181 when I record hours this way I can note time in type at a detailed level.
For what its worth with the PA-28 airframe it seems that some places to allow you to fly the lower rated planes if you are checked out in the higher power ones. The same basic frame was built in a 140, 160, 180 and 235HP variant over the years and has little differences aside from useful load and V speeds. For example at the place I go if you are checked out in the Archer first you are allowed to fly the Warrior with out a checkout.
This will also extend to ownership should that be the path you go down. In that case you insurance company may require a certain amount of hours of time in type before you are allowed to solo your plane. Keeping that in mind you are not actually prevented from buying the plane and will be insured under the stipulation that the first hours in the plane are with an instructor. When a buddy of mine (instrument rated and close to 600 hours at the time) upgraded from his 72 Archer to a 95 Saratoga HP his insurance company mandated he do 25 hours in type with an instructor before taking the plane solo. The first 25 hours he flew his plane were with an instructor (this included transporting the plane from the factory in Vero Beach to his home field).
You can legally fly both planes once you have your PPL. What someone will let you fly should be pretty well addressed above. Neither the 172 or 152 requires a specific type rating like larger planes do.
share|improve this answer
Good answer. Note that no special endorsement is needed for a non-complex aircraft that has either a constant speed prop, flaps, or retractable gear or any two of the same. The definition of complex is the combination of all three. – Jonathan Walters Feb 23 at 20:27
Answer has been updated to reflect – Dave Feb 23 at 20:42
Just curious - you mention the requirement for 10 hours in type for the Lance and 25 with a club CFI. What if you already have 25+ hours solo time in type - would they accept your logged time, or would they still require time with their CFI? I realize that this is very club specific, so probably wouldn't rate a question of its own. I suppose at a general level, it could be a stand-alone question. – FreeMan Feb 24 at 17:25
Thanks for the answer. Just to confirm, in the eyes of the FAA, I'm legal to fly any SEL, fixed pitch, under 200 hp, no gear etc., with a PPL, regardless of the make, high wing, low wing, etc. Practically speaking, however, any rental or club situation would likely be more restrictive and require a check out, probably for any aircraft they own. Is that correct? – PJNoes Feb 24 at 17:49
@FreeMan i was mistaken (and have updated my answer) according to their site they require 25 hours time in type and a 5 hour checkout in their lance, but this is specific to them. – Dave Feb 24 at 18:04
discard
