Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
There is a hole on the belly fairing circled in yellow. I guess is an air intake but I tried searching some info and couldn't find anything. Atr 75
Source
share|improve this question
up vote 15 down vote accepted
It is the ram air intake for the air conditioning system. There are two of them, one on each side.
Here is an image from the ATR-72 FCOM:
ATR 72
ATR-72 Air conditioning System, image from 737ng.co.uk
Details from the same document:
The air conditioning system is supplied by air processed through two packs which regulate air flow and temperature. The two packs are installed in the main landing gear fairings and operate automatically and independently.
The left pack supplies the cabin and cockpit air conditioned; the right pack supplies only the cabin air conditioned.
Also, as @Jonathan Walters points out, the intake is a good example of NACA inlet (or NACA scoop) and are found in a number of aircraft, for example Boeing 737.
share|improve this answer
You might consider adding that it is an example of a "NACA scoop" – Jonathan Walters Jan 29 at 0:14
discard
