Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Which are the aircraft models that need their tail to be supported by a jack when empty?
Wikipedia says this:
Aircraft Tripod Jack
They are used to support a parked aircraft to prevent their tail from drooping or even falling to the ground. When the passengers in the front get off an aircraft, the aircraft becomes tail heavy and the tail will droop..... When needed, they are tugged to the tail and setup by manpower. Once setup, no supervision to the jack is needed until the aircraft is ready to leave.
Are there even commercial airliners that need to be supported this way every time they load / unload? Sounded like a lot of work for ground staff. Was this a legacy equipment thing or still in use today?
https://en.wikipedia.org/wiki/Ground_support_equipment
share|improve this question
Related – fooot Jan 24 at 6:24
Anecdotally, Dad and some colleagues on a business trip got a chance to look round Concorde in Paris : the guard counted them; six; and asked them not all to go to the rear of the cabin at the same time... – Brian Drummond Jan 24 at 10:39
The Quest Kodiak uses these. – Jonathan Walters Jan 24 at 13:55
Tripods are mostly found in cargo aircraft (and combis) as the cg shift is severe there (particularly for front loading). A good example is the Boeing 747s. Also used in DC10/MD11s used as freighters.
747F
Image from reddit.com
Some 747-400 combis also use these, though it is mainly for cargo loading.
747-400M
Photo: Je89 W. / Source: PlanePictures.Net
Some passenger airliners are prone to tipping (737-900 comes to mind) and are usually supported by a pole rather than by a tail stand (same procedure is used in a KC-135 tankter too). For example, a Boeing 737-932ER with tail support.
B737-900
Image from airliners.net
The tail supports are not strictly necessary and the loading can be carried out sequentially (from front to back) for safe operation, but are used as a precaution. In some aircraft (like ATR-72 and Saab 340, called pogo sticks) small tubings are attached to the rear fuselage to prevent tipping over when loading/unloading.
ATR 72
Image from theflyingengineer.com
The nose can be tethered to prevent tipping during loading/unloading as done in this Koreanair 747F
747F
Image from koreanair.com
share|improve this answer
Also in some older aircraft such as 727 the airstairs performed this function. – TomMcW Jan 24 at 17:39
DC-8 freighters used tail supports as a safety precaution. As I remember, if you loaded them properly the support wasn't needed, but people didn't always do that. The cargo door was forward of the wing. I've long since thrown out my DC-8 weight & balance manuals, but as best I remember, the proper protocol was to put the desired most forward ULDs in first and slide them to their positions forward of the door. Next you would put in the rearmost ULD, but then move it just far enough aft to get the next ULD on, then move it and the previous one just enough aft to get the next one on, and so on. At some point you had enough weight forward of the main gear to start moving pallets all the way to the rear. If you miscalculated, the airplane would sit on the installed tail support. This reportedly happened at Newark, as I remember, in the early 1990s, but they had neglected to put up the tail support. The airplane sat on it's tail.
The same attention to balance was also needed when unloading. Read this link for an unloading accident when the tail stand collapsed. Three loaders were able to get out of the way, one got his foot caught, sustaining serious injury.
discard
