Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I came across this interesting factoid in another SE Aviation answer (How flat does a runway need to be?):
seaplanes often use a curved takeoff run.
I'm trying to imagine why but cannot come up with a good reason.
Does anyone know why?
share|improve this question
You landed on a curved lake? – jamesqf Jan 21 at 7:01
12
@jamesqf every lake is curved – andrewmh20 Jan 21 at 8:21
@andrewmh20: Obviously, I meant curved as in an L or C shape, not curved as in round, so that you don't have room for a straight takeoff run. (And FWIW, I've flown over a lake in Northern California that's square.) – jamesqf Jan 21 at 18:49
@jamesqf I meant curved as in curved by the earth. – andrewmh20 Jan 21 at 18:49
19
@andrewmh20: But that Euclidian curved surface is in fact flat in the spherical coordinate system of gravity, air pressure, and everything else relevant to taking off :-) – jamesqf Jan 21 at 19:51
Years ago now I gave a fair amount of instruction for seaplane ratings. I remember it quite fondly as seaplanes combine the fun of flying with aspects of the fun of boating. There were three conditions in which we used curved takeoff runs.
The most frequent curved takeoffs were on rivers, which tend to not run in a straight line, and even for those portions of a river that do, there may be rapids to stay clear of, so following the bend of a river or weaving between rapids was not unusual. In my case, the rivers were the McKenzie and Willamette, both in Oregon, USA. If you're ever in Eugene, Oregon, go down to Skinner's Butte Park on the Willamette River. On the upstream end of the park is the Ferry Street bridge. On the downstream end is the Washington-Jefferson bridge. In the 1970s we used to operate on the water between them, avoiding the rapids. We stored the airplane for a time on the Skinner's Butte Park shore line. That was legal and safe back then.
The next most frequent usage of curved takeoffs was to get off ponds that were not wide enough to allow a straight line takeoff. However, you can do it taking off in a curve along the perimeter of the pond. If you ever happen to fly over Daniels Field alongside Interstate 5 about 20 miles north of Eugene, Oregon, you'll see a lake/pond alongside the runway with a small island in the middle. There is no straight line you can draw on that pond that comfortably gives you room for takeoff, but you can circle the island and get into the air without difficulty.
The third circumstance we didn't have to use often was when we had to run across our own wake to be able to get up on the step on glassy water. For example, Waldo Lake in the Oregon Cascades is at 5,400 feet elevation. A J-3 cub with an 85 horse engine and with two people on board simply cannot get up on the step when the surface of the lake is a dead calm. However, if you get going in a curved path, you can get up on the step when you run across your own wake. Once you're on the step, you can then put the airplane up on one float and get enough airspeed to take off. Just as a matter of information, seaplane operation on Waldo Lake is now prohibited.
share|improve this answer
15
I'd love to see video of a seaplane taking off circling an island like you describe. Just sounds cool. – Insane Jan 21 at 14:03
Is 'On the step' the same as the state of planing that boat hulls can achieve? – Gusdor Jan 21 at 14:29
20
@Gusdor Essentially; basically a floatplane has to break the suction of the water - kind of like pulling your boot out of mud - and if the water isn't moving at all then it has to do that all by itself. If there are some waves, or a wake, or any kind of discontinuity in the water, then that gives the aircraft the momentary break it needs to overcome that initial suction. "The step" in this context refers to the step-up shape you see partway down the float (or hull); when you're "on the step" then you're using the part of the float forward of that step to hydroplane. – anaximander Jan 21 at 15:35
11
Excellent answer. I learned something new. I had never realized that taking off from a glassy water surface was harder. Thanks! – curious_cat Jan 21 at 16:26
11
"weaving between rapids was not unusual" Really puts the other questions on the site about takeoff and landing in perspective. – blahdiblah Jan 21 at 23:03
One reason for a curved takeoff is the downwind arc method as described on page 4-14 of the FAA Seaplane, Skiplane, and Float/Ski Equipped Helicopter Operations Handbook (FAA-H-8083-23):
DOWNWIND ARC
The other crosswind takeoff technique results in a curved path across the water, starting somewhat into the wind and turning gradually downwind during the takeoff run. This reduces the actual crosswind component at the beginning of the takeoff, when the seaplane is most susceptible to weathervaning. As the aerodynamic controls become more effective, the pilot balances the side loads imposed by the wind with the skidding force of an intentional turn, as always, holding the upwind wing down with the ailerons. [Figure 4-17]
The pilot plans a curved path and follows this arc to produce sufficient centrifugal force so that the seaplane tends to lean outward against the wind force. During the run, the pilot can adjust the rate of turn by varying rudder pressure, thereby increasing or decreasing the centrifugal force to compensate for a changing wind force. In practice, it is quite simple to plan sufficient curvature of the takeoff path to cancel out strong crosswinds, even on very narrow rivers. Note that the tightest part of the downwind arc is when the seaplane is traveling at slower speeds.
The waves are running separate from the wind. When the plane has pick up enough out of the water it turns into the wind.
discard
