Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Most large aircraft and some fighters have blunt, rounded nose cone. OTOH many fighters (that don't use the nose for air intake) and notably the two supersonic airliners (Concorde, TU-144) have the sharp tip for a nose cone.
What is the aerodynamic justification for that? What advantages and disadvantages does the "blunt" nose cone provide - or why don't all airplanes have the sharp spike nose cone (which "feels" like the obviously optimal aerodynamic choice - obviously that "feel" is somehow flawed?)
share|improve this question
up vote 15 down vote accepted
In subsonic flow the air can react to the approaching vehicle since the pressure field around it extends forward, too. This means that a suction area on one side of the fuselage or wing will already start to pull molecules in before they reach the vehicle itself which causes this suction. A round nose allows the flow to come from a range of angles without creating too much drag. Aerodynamically speaking, the stagnation point can be moved without problems.
In supersonic flow, the air has no indication of the approaching vehicle. The first contact will cause a sudden change in direction, called a shock. For drag reduction it is important to make the shock as weak as possible, which means that the change in direction should be as small as possible. This can best be achieved by a slender, pointy tip.
Note the downward position of the intake cone of the SR-71 engine nacelle in the picture below: It is angled so that at Mach 3.2 the cone is symmetrical to the oncoming flow (which gives you a pretty good indication of the angle of attack of the whole plane).
SR-71 during take-off
SR-71 during take-off (picture source). Not only is the cone angled downward, but also canted in because the flow is pressed sideways by the aircraft's forebody in supersonic flight.
In hypersonic flow (Mach > 5) a blunt nose might again be preferable if the nose's materials put an upper limit on aerodynamic heating. A pointed tip will produce an attached shock which will heat the tip to something close to the stagnation temperature of the flow. A blunt nose, however, will cause a separated shock. This creates more drag and higher heat loads overall, but allows to spread the heat over a larger area and produces lower peak loads. The Space Shuttle had such a blunt nose, since drag minimization is not a priority for a re-entry vehicle.
share|improve this answer
...and yet, most rockets nowadays (definitely supersonic vehicles) have blunt noses... any reason for that? – SF. Jan 20 at 14:25
@SF: Yes, heat. The pointed tip has an attached shock with massive heat transfer into the small tip. A blunt tip will create more drag, but has a separated shock which will produce more heat overall, but lower peaks. This is only important above Mach 5, so I did not add it here since the question concerns aircraft. I answered only because I could not bear to see the rambling of aeroalias as the only answer here. – Peter Kämpf Jan 20 at 15:24
Aircraft design is full of compromises. In case of aircraft nose design, the main factor is to reduce drag. As you yourself noted, the main difference is in flow regime, i.e. subsonic and supersonic. There are different types of drag- skin (or friction) drag, form drag and wave drag (which becomes important only at supersonic speeds.
For subsonic flow, the main drag components are the first two- skin friction and form drag. Here, if we consider the fuselage to be a cylinder with the nose in front (which is a pretty good approximation), the blunt nose configuration gives a lesser drag coefficient (non-dimensional drag) compared to the conical or sharp nosed one. This means that all other things being equal, the blunt nose has lesser drag compared to sharp ones in subsonic flow. In particular, the blunt nose has lesser surface area compared to the sharp, long ones and thus lesser skin friction drag.
Forebody Drag
Image from Fluid Dynamic Drag by Hoerner
From the above figure, you can see that the blunt nose is actually better compared to a sharp nose as far as drag is concerned.
3D Drag
However, as the aircraft goes to supersonic flow, the main concern becomes wave drag. Here, the sharp nose keeps the shock wave clear of the aircraft.
Shock wave
Image from wotzup.com
Another thing is that in a sharp section, the cross sectional area varies gradually, which helps in prevention of local acceleration (which can result in local sonic conditions). This is the reason why you see aircraft that fly subsonic over most of their flight regime have blunt noses, while those fly supersonic over most of their flight path have sharp noses.
Of course there are other points to consider too:
  • The manufacturing cost of the sharp nose is usually greater than a blunt nose (has more area, for one).
  • A long, sharp nose will affect visibility during landings (Concorde had a droop-down nose because of this). Also, parking in airport ramps is going to be difficult.
  • A sharp nose will have lesser volume (for mounting radar, for example). As a result, most supersonic aircraft actually have a sightly modified nose section (elliptical or oogival, for example), especially, fighter aircraft.
Nose cone volume
Image from spaceflightsystems.grc.nasa.gov
As can be seen, an elliptical section with same base diameter and height has double the volume of a conical one. In some cases, where the nose landing gear retracts into the nose (like A350), this will be important.
On a different application, I suppose this would also explain why handgun bullets are blunt-tipped whereas rifle bullets are pointed. – TomMcW Jan 18 at 18:15
discard
