Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I saw this photo at another interesting question:
There's an open square panel. What is it?
P.S. Any tag suggestions are welcome. All I could think of was "tail".
EDIT: are there any other tags for this kind of thing? The APU tag seems to be a crystal ball because I had no idea what it was at the time.
share|improve this question
I'm guessing it's APU related. – Fred Larson Jan 18 at 1:47
Next question – TomMcW Jan 18 at 19:10
It is the Auxiliary Power Unit (APU) inlet door.
APU inlet
Image from Boeing Aero Magazine
share|improve this answer
Next question: why is does the inlet face upwards, where rain can get in? If it opened downwards, they wouldn't have to put a door on it at all. – Level River St Jan 18 at 10:03
@steveverrill I don't think the door is for rain protection but for aerodynamics. Afaik the APU is not used in-flight. So you can cover the inlet with a door because a "hole" in the fuselage would generate drag. – André Stannek Jan 18 at 10:24
it if were facing down, it would be subject to FOD. it probably has an inertial separator not just for rain, but for debris as well. – rbp Jan 18 at 16:36
oh and here i thought the question was asking about the square open panel below the tail number and door... @DrZ214 – Michael Jan 18 at 17:42
@steveverrill Yeah, it's prob not advisable to let water sit in there while it's not running. I'm assuming the door is normally only open when the apu is in use. So preventing rain ingress may be one reason the door is there. The diagram does show a drain for the exhaust, though. I guess because it can't be closed. – TomMcW Jan 18 at 18:50
discard
