Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
From here it is seen that many multi-engine propeller planes spin their propellers in opposite directions. To avoid producing "left" and "right" types of the engine, a gearbox is fitted.
In contrast, jet engines usually spin in the same direction. Why is the spinning direction less important for a jet engine than for a propeller engine?
A Boeing 777 may have a turbine fan as large as 325 cm in diameter (GE90-115B). Not every propeller is that large.
share|improve this question
up vote 29 down vote accepted
This is sort of explained in the linked question already. Specifically this answer (which I consider better than the accepted one above it) says:
Today, high power propeller aircraft tend to use identical engines but left- and right-handed gearboxes so the propellers run in both directions. This is less due to gyro effects and mostly to produce benign stall characteristics. The prop wash of a propeller increases the local angle of attack on the wing on one side and decreases it on the other side, so the wing will stall first on the side with bigger angle of attack. If this side is always to the right of the propellers, the aircraft will roll right in a stall.
In a turbofan the nozzle directs the flow below the wing aft of the leading edge, focuses it more and uses guide vanes to stop its rotation, so this effect does not occur. This eliminates the most important factor for deciding to use counter-rotating propellers.
Combine with the fact that most turbofans are not geared, so the whole engine would have to be mirrored, which would complicate maintenance a lot more than just having mirrored gearboxes and propellers does for turboprops.
share|improve this answer
I think the reason has more to do with the Propeller (P) factor and the rudder corrections required to over come it. This effect does not arise from gyroscopic effects - it is an aerodynamic phenomenon.
Low airspeed and high angle of attack flight causes the blade descending on one side of the propeller disk to see a lower angle of attack than it sees when ascending on the opposite side of the propeller disk. The blade on the side seeing the higher angle of attack generates more thrust creating a torque about a roughly vertical axis. This torque twists the aircraft in yaw and must be resisted by a force created by a rudder deflection if steady flight is to be maintained.
High power propellers will produce a proportionately high torque about the vertical axis at high angles of attack and low airspeed. Thus, high power aircraft will require a significant rudder input to overcome this torque and keep the aircraft aligned with the relative airflow or the runway or to keep it traveling through the air in a straight line and on a constant heading. When operating at high power and low airspeed the required rudder input can be very considerable. A long climb can give a pilot one very tired leg. Also, on applying power by increasing engine rpm the pilot must also make a coordinated rudder input as the amount of rudder input depends on the speed of the propeller. Counter rotating propellers eliminate this P torque and any corrective rudder input requirement for changes in propeller rpm or aircraft angle of attack.
In addition, pitching and yawing an aircraft can change the angle of entry of air into the propeller disk. Once again, this can cause uneven thrust around the propeller disk creating a torque on the aircraft around some axis other than the one the pilot intended. This torque then requires yet another coordinated input from the pilot to maintain the desired flight path. The axes controls are said to be coupled and pilot inputs become complicated and non-obvious increasing pilot work load.
Finally, coupling of two axes in this way can cause an aircraft to continuously oscillate about the pitch and yaw axes and these oscillations can be out of phase causing the aircraft to continually vary pitch and yaw creating an uncomfortable sensation for those on board.
Counter rotating propellers can eliminate all the effects of P factor.
The inlet ducts of jet engines direct the airflow into the engine and the turbine disks and align it with the turbine shaft axis perpendicular to the plane of the blade disk. As a result, P factor does not come into play here, jets do not have the problems caused by P factor, and jets do not need counter rotation to overcome it.
You are right about the P-factor, but if you have ever stalled a multi-engined aircraft at power with all props turning in the same direction, you would not write the first sentence. Rudder trim would help with the sore leg; nothing helps when the aircraft rolls violently when it stalls. – Peter Kämpf Jan 8 at 4:33
discard
