Take the 2-minute tour ×
It is becoming accepted that the Boeing 777 is the world's safest aircraft. There must be a reason for this of course, and aircraft designers should know it.
So my question is, can't we take all the safety merits of a B777 and copy them into other models and bring all airplanes to the same level of safety?
share|improve this question
retro fitting things into older airplanes is very expensive and not always possible –  ratchet freak Mar 17 '14 at 14:22
Why down vote? As an aviation enthusiast to me the question seems pertinent. –  Fabrizio Mazzoni Mar 17 '14 at 14:43
The safest airliner is the one that is built, towed into a hangar, and never flown, but you'll recall the old nautical adage: "A ship in harbor is safe, but that is not what ships are built for." –  voretaq7 Mar 17 '14 at 15:20
up vote 14 down vote accepted
What's the "safest aircraft" depends in large part on who operates it, how they operate it, and where.
For many operators the 777 will be their prestige airliner, being assigned the most senior, most experienced, crews, the best maintenance, etc. etc..
That alone will mean less incidents and accidents than other types. They also have the range and ceiling to be able to fly around or over most serious weather. A 30 minute detour on a 10 hour trip can be made up, a 30 minute detour on a 1 hour trip in a 737 or A320 can't be (even if the aircraft would have the spare fuel to fly that detour).
The rest is mostly statistics. I seriously doubt there have been statistically more accidents per hour flown or per rotation on say an A340 as compared to a 777. There have been more airframe losses, but those include several lost on the ground due to them being stuck on airports in warzones (think what happened on Sri Lanka where Tamil separatist mortar bombs destroyed several airliners on the ground, damaging the until then flawless safety record of the type).
There have been AFAIK 3 777 hull losses (including the missing MH370) in flight.
Given the far higher number of say 737s in operation, and the far longer service history of that type, often with operators with shady operational procedures (more than a few are for example blacklisted by the EU) it's little surprise there have been more hull losses among the type. But comparing say the 737-900 only with the 777, with somewhat similar technology and number in service, as well as similar prestige level for crew assignments, you'll find a similar safety record.
share|improve this answer
+1, I also think that that the 777 experiences a lower number of pressurisation cycles in the course of its lifetime than a shorter range 737. This makes it less susceptible to airframe stress and cracks than a 737. –  shortstheory Mar 17 '14 at 15:33
@shortstheory both pressurization and takeoff/landing cycles have a lot to do with stress and wear. As 777s are basically exclusively long haul, they see much fewer of both. –  egid Mar 18 '14 at 3:30
@shortstheory true, but then the 737 also will encounter more frequent depot level maintenance. Maintenance during which there are checks performed for just those things IF procedures are followed correctly. –  jwenting Mar 18 '14 at 15:37
The 777 is also fairly new, at only 20 years old - that means they have fairly up to date safety features, and that they aren't being flown around far-flung, lightly regulated parts of the world by small cargo carriers and cowboy airlines. –  Jon Story Dec 15 '14 at 17:12
discard
