Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
What is the black pod starboard of the front landing gear on this F-16-I? At first I thought that it was a laser finder, but upon closer inspection it seems to resemble some type of short cannon. What might it be?
F-16
share|improve this question
up vote 16 down vote accepted
What you seem to have found is the Litening Targeting Pod.
Northrop Grumman's widely fielded LITENING system is a combat proven, self-contained, multi-sensor targeting and surveillance system. LITENING enables aircrews to detect, acquire, auto-track and identify targets at extremely long ranges for weapon delivery or nontraditional intelligence, surveillance and reconnaissance missions. Source
pod
The F16 does have a cannon as well, but it's located on the port side under and aft of the canopy: cannon
share|improve this answer
Thank you! Might I ask how you found that? My google-fu must need some improving. – dotancohen Mar 13 '14 at 9:12
@i googled 'f16 weapons', came up with this image and was able to make out something about a pod that looked similar :) happy to help – MikeFoxtrot Mar 13 '14 at 9:14
Thank you, Manfred! – dotancohen Mar 13 '14 at 9:16
Mind that an external gun pod for the F-16 was created when it was planned to replace the A-10 with the F-16. It was the GAU-13 and used a scaled down version of the A-10s GAU-8 gun. It was however never produced in numbers and never entered operational service because of its poor accuracy. – jwenting Mar 13 '14 at 12:18
At the start of Desert Storm the USAF did in fact deploy a squadron of 'A-16s' to perform CAS and ground attack using a podded GAU-8. Unfortunately, the only place on an F-16 (of that era anyway) to load an ECM pod is the centerline station, which is also the only place the GAU-8 can be loaded. It only took a couple of near miss SAM engagements before the 'A-16' was converted back into a proper F-16. – Jim In Texas May 9 '14 at 20:45
discard
