Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
What is the function of the scissors link on the rotor of a helicopter?
I assume it has something to do with the flight controls, but I'm not quite sure what.
share|improve this question
@yadi I've edited your question to be a little less vague (and to match up with the answer). If you were talking about some other scissors link in a different flight control system please open a new question, with more detail :-) – voretaq7 Mar 7 '14 at 16:46
up vote 6 down vote accepted
the scissor link ensures the upper swashplate rotates with the rotor blades (and the lower with the body) while ensuring enough movement for the plate to control the craft (tilting and up and down).
the connector between the mast and the upper swash plate, has a counter weight
(http://en.wikipedia.org/wiki/File:Robinson-Rotorhead.jpg)
To keep the stationary swashplate from rotating with the rotor, a scissor mechanism is added. The scissor connects the swashplate to the fuselage. The scissor consists of 2 parts which are connected by a hinge. One end is connected to the helicopter using a hinge, while the other is connected using a ball joint. This means that the swashplate can move freely up and down, and can freely tilt in any direction, but can't rotate around the mast.[source]
this is needed because the control linkage is typically attached with balljoints which would otherwise allow for too much relative movement.
share|improve this answer
discard
