Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I was trying to explain to someone why the cabin is pressurized (no one wants hypoxia) and that led to discussion about the emergency oxygen masks available on airliners.
If a person didn't put on their oxygen mask, would they be able to survive the lack of oxygen while making an emergency descent to a safe altitude? Would they sustain severe brain injury?
share|improve this question
Thanks for sharing that really good article, @JanHudec! – Jeff Bridgman Mar 4 '14 at 22:21
I wonder if there's a risk of decompression sickness from losing cabin pressure. – Adam Davis Mar 5 '14 at 15:30
@AdamDavis, the article linked to by Jan goes into that. – Jeff Bridgman Mar 5 '14 at 17:20
The most interesting point in that article is something that I always wondered: if I can hold my breath for 30sec, why do I have to put those masks in such a hurry? The answer: because you won't be able to hold you breath, the air pressure is so diff. that you can't not expel your air. – woliveirajr Mar 10 '14 at 12:07
up vote 43 down vote accepted
I did high altitude training about three months ago, up to 30,000 feet simulated altitude. Here's the timeline:
  • Within 30 seconds (oximeter 100-95): noticed physical symptoms beginning. I could tell that something was wrong, but felt functional.
  • Within 60 seconds (oximeter ~90): mild headache. Still able to write my name. Not feeling good, but acceptable.
  • Within 3 minutes (oximeter ~80): Able to do simple tasks when specifically directed (thread a nut onto a bolt), but completely unable to multitask at even the simplest things (tried to put my pen down...didn't notice that I missed the desk - it landed on the floor.)
  • Within ?? minutes (oximeter ~70): I am no longer able to perceive the passage of time. No longer able to take meaningful notes. My signature is still legible - instinctive muscle memory apparently doesn't degrade nearly as fast.
  • Within 6 minutes (oximeter unknown): I have taken another pen from my pocket and am playing the knife game from "Alien" with it. This is much more interesting than paying attention to the directions from the instructors. I don't notice anything odd about my behavior.
  • Immediately after: An instructor gives me a direct command to put my mask on. I comply.
Total time in chamber: 7 minutes. Time of useful consciousness in chamber: about 2 minutes
So, to answer your question: It depends. I can safely say that seven minutes at 30,000 foot environment won't guarantee death (because I've survived it), and it won't guarantee severe brain injury (they let me keep flying) but on the other hand, I'm young and I exercise. The best answer I can give is the same one that applies to scud running:
Just because the guy before you was able to do it, doesn't mean you'll be able to do it.
share|improve this answer
Very entertaining and educational (a bit heavy on bold text, though) :D ... are there any advised breathing techniques that will prolong the process? – yankeekilo Mar 4 '14 at 12:27
Anecdotal, there are people who climb Mt. Everest without oxygen (29,0029ft or so), which would be somewhere into the hours of conciousness. That being said, they usually talk about feeling high the whole time and, frankly, most mountaineers thinks those people are crazy, so... Take it as you will. – Jay Carr Mar 4 '14 at 15:47
@JayCarr they're also climbing Mt. Everest - we can assume (a) they're in superlative physical condition - though I'd agree with the other climbers about questionable mental status, and (b) they're taking quite a while to make the ascent, allowing their bodies to adjust to the pressure change. The relatively quick transitions in a high-altitude chamber (or the nearly instant transition in an explosive decompression) don't offer the same opportunity for your body to adjust. – voretaq7 Mar 4 '14 at 16:42
14
@yankeekilo - I wouldn't have had to use so much bold if StackExchange hadn't disabled the <blink> tag. – Steve V. Mar 4 '14 at 17:26
@yankeekilo - Don't be ridiculous. The story of how I doodled that gravatar starts out "There I was, inverted on the ILS, chief pilot in the jumpseat, doing formation flight with the space shuttle..." – Steve V. Mar 4 '14 at 20:04
Short answer? It's entirely possible that not putting on a mask could result in death.
Long answer:
The classic example of hypoxia is the Payne Stewart Learjet crash that happened in 1999; the jet lost cabin pressure (and the crew lost consciousness) sometime in the 6 minutes between 23,000 feet and 36,500 feet. All 6 aboard perished in the crash.
From the NTSB report, which the Wikipedia article quotes:
Research has shown that a period of as little as 8 seconds without supplemental oxygen following rapid depressurization to about 30,000 feet (9,100 m) may cause a drop in oxygen saturation that can significantly impair cognitive functioning and increase the amount of time required to complete complex tasks.
There are tables available that show time of useful consciousness. Above FL300 (30,000 feet, or around 9,150m), a healthy human will have less than 3 minutes of useful consciousness. Prolonged hypoxia, at any altitude, can have serious repercussions. The National Institute of Health states that "[some] brain cells start dying less than 5 minutes after their oxygen supply disappears. As a result, brain hypoxia can rapidly cause severe brain damage or death" (source).
I'd vote for Helios 522 as 'the classic', with lots of supplemental oxygen, and a bus-load of people, yet they were all incapacitated and no one made it out alive. It happened a couple of years later though. – falstro Mar 5 '14 at 14:36
Pilots didn't know the pressure was too low and passed out on Helios 522. Although the hypoxia is not the cause of death, slamming into the side of a hill is. Hypoxia at that altitude would usually result in an irreversible coma. – ptgflyer Dec 25 '14 at 16:57
@ptgflyer So if those people on Helios 522 were somehow magically rescued, would they be vegetables? – Marky Mark Feb 11 '15 at 0:24
Sure, vegetables. – ptgflyer Feb 14 '15 at 18:27
That would depend on at least the following:
  1. how high the cabin got during the process
  2. how long it stayed high
  3. the physical condition of the passenger
  4. perhaps to some degree how much oxygen was coming out of the masks of adjacent passengers
I went through NASA's altitude chamber program at the Johnson Spaceflight Center back in the early 80s. They wouldn't take the chamber higher than 25,000 for civilians. I was in very good shape back then (hard to believe now) and stayed functional the longest, but when they finally told me to put my mask back on, they told me I only got it half way to my face. An instructor had to come over and assist me.
Did I suffer brain damage? Some might contend I did.
Seriously, I Googled "survivability at high altitudes" and saw lots of info.
The other answers focus on the physiology of failing to put a mask on, but I am going to offer another take on this.
Whether you die from not putting on a mask depends on one thing: Did the pilots get their masks on before useful consciousness ran out? If they did, you live. If they didn't, you die. It is as simple as that. In the case the pilots get their masks on and no one else does, they will initiate an emergency descent. This descent is typically initiated from memory items and not a checklist, so it can be initiated quickly. The goal of the emergency descent is to be at 10,000 ft iASAP (for us the goal was under 4 minutes), and many jet aircraft can get there faster. The only regulations I am aware of regarding the descent is that you must be below 25,000 ft in under 2 minutes (25.841; assuming complete loss of cabin).
If the emergency descent is initiated and in all likelyhood it won't matter if you put the mask on or not, you'll wake up during the descent and it'll only have been a few minutes. Its always better to put the mask on, but it won't be the deciding factor, the pilots masks will be.
I'll also point out the O2 masks the pilots have are vastly different than those the passengers get. Pax get chemical O2 generators that last about 15 minutes once activated (by pulling the tubing down) and attatch with a flimsy rubber band. The pilots get quick-don masks fed by an O2 cylinder. To don the masks you simply grab it, the O2 pressure inflates the webbing around the mask. Then you slip it on your head, let go of it and the mask compresses around your face. Twist the mask regulator to Emergency and you have positive pressure forced flow O2 for the descent.
§25.841 Pressurized cabins. (a) Pressurized cabins and compartments to be occupied must be equipped to provide a cabin pressure altitude of not more than 8,000 feet at the maximum operating altitude of the airplane under normal operating conditions.
(2) The airplane must be designed so that occupants will not be exposed to a cabin pressure altitude that exceeds the following after decompression from any failure condition not shown to be extremely improbable:
(i) Twenty-five thousand (25,000) feet for more than 2 minutes; or
(ii) Forty thousand (40,000) feet for any duration.
What regulation requires you to be below 25,000 feet in two minutes? I was going to write an answer similar to this, which is more the real answer to the question asked, but couldn't find the emergency descent rule. I thought that you had to reach 10,000 feet in four minutes or less, but apparently I was wrong.... – Lnafziger Mar 5 '14 at 3:59
@Lnafziger I added a reference for the 2 minutes to FL250. I was also taught the 4 minute to 10k figure and this is what we used at my 121 carrier, but I cannot find a reference for it. 121.333 has a reference to 4 minutes but it deals with O2 requirements for flights at certain altitudes and the ability to descend in that timeframe. Still looking! – casey Mar 5 '14 at 4:16
@Lnafziger and I should add my interpretation of the 2 minute figure is a bit of a stretch, as complete rapid decomp is probably "extremely improbable" and the quoted reg excludes those cases. – casey Mar 5 '14 at 4:18
@Lnafziger as best I can tell, the 4 minute rule may arise from avoiding the need to carry something more substantive than short-lived chemical O2 generators for the pax for high altitude flights. – casey Mar 5 '14 at 4:33
I suppose FAR 135.89 mandating at least one pilot being on oxygen above FL120 doesn't apply to airliners? I find that super-surprising... – Jeff Bridgman Mar 5 '14 at 17:23
discard
