Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm not sure if it's just in Boeing aircraft, but I've heard that Cost Index has something to do with flight planning but have no idea what it is.
What is it for and how is it calculated? (I'm happy for the simple version of the calculation if it's too hard to explain)
share|improve this question
up vote 11 down vote accepted
The cost index is a number used in the Flight Management System (FMS) to optimize the aircraft's speed. It gives the ratio between the unit cost of time and the unit cost of fuel.
With this number, and knowledge about the aircraft's performance, it is possible to calculate the optimal speed for the aircraft, which results in the lowest total cost.
Speeds slower than the optimal speed will result in less fuel burn, but also in more flying time. The cost of the extra flying time outweighs the fuel savings at speeds below the optimum speed.
Speeds faster than the optimal speed will result in more fuel burn, but also in less flying time. The saving of less flight time do not outweigh the fuel burn at speeds above the optimum speed.
A low cost index means that the cost of time is low or that fuel is expensive. It will result in a low speed. High cost index means high cost of time (e.g. passengers about to miss their flight connection) or low fuel price (rare these days).
At the minimum cost index (0) only fuel counts. This will result in the aircraft flying at Maximum Range Cruise. At the maximum cost index only time counts. This will result in the aircraft flying at Maximum Cruise Speed (Vmo / Mmo with a buffer)
Airlines generally have a standard cost index they use for planning and adjust them on a flight by flight basis.
This document from Airbus explains the cost index in more detail.
share|improve this answer
According to this article, Cost Index of a flight is:
The ratio of fuel costs to all other costs.
So the lower the Cost Index, the lower the fuel burn in relation to the other operational costs of the trip.
This generally means flying the airplane slower and higher in order to conserve fuel, but that is offset by the higher maintenance costs due to the airplane being in the air longer and inspections becoming due sooner, so is true only to a certain point.
It is a generic term, not specific to Boeing.
While somebody else might be able to explain it better, Cost Index is the relationship between fuel use and flight time.
High Cost Index: Fast flight, low crew times, high fuel use, etc.
Low Cost Index: Slow flights, high crew times, low fuel use, etc.
It's always a complex compromise on what is best, and policies vary between airlines and how they use their aircraft. I don't think you can 'do' a calculation though in that sense, since it's a value which often comes from computer formulas.
discard
