Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
What happens to a turbine engine from the time that a start is initiated until stable idle is achieved?
What can go wrong?
share|improve this question
Of course, everyone knows that to start the engine of the Phoenix, you shoot it... – CGCampbell Jul 23 '14 at 18:16
The means of starting most turbine engines is high pressure bleed air. This bleed source typically comes from an APU but may also come from an already running engine (crossbleed start) or an external huffer cart.
In some airplanes the start is completely FADEC controlled and need only be initiated and monitored by the flight crew, and in other airplanes certain steps must be manually initiated.
The process below best describes a turbofan engine. Read @Falk s answer for information on differences with turboprop engines.
Turbofan basics
Refer to the image below (Credit: K. Aainsqatsi, Wikipedia): Turbofan diagram
The portions of the engine I will be referring to below are:
  • The N1 fan, N1 shaft and N1 turbine which are displayed in green and labelled "Fan/Low-pressure compressor", "Low pressure shaft" and "Low pressure turbine". These units are connected and move as one piece.
  • The N2 compressor, N2 shaft and N2 turbine, displayed in purple and labelled "High pressure compressor", "High Pressure shaft" and "High pressure turbine". These are connected and move as one, but independently of the N1 shaft. Un-pictured is an accessory drive that is geared to the N2 shaft to drive engine accessories.
  • The hot section, pictured yellow and labelled "Combustion chamber". This is home to a constantly burning fire in a jet engine.
Engine Start
The process of the engine starting follows this basic formula
  • Through the opening of bleed air valves, bleed air is sent to an air turbine starter. These devices typically use the high pressure bleed air to spin and engage a centrifugal clutch connected to the engines accessory drive. This in turn causes the N2 shaft within the engine to spin.
  • With the N2 shaft spinning, the N2 compressor and the N2 turbines are spinning. This begins to force air through the engine from front to back.
  • With the accessory shaft and N2 shafts spinning, accessories should start working and this can be verified by oil pressure indications on the EICAS.
  • With increased N2 rotation, ignition will be turned on. These igniters are located in the hot section of the engine and produce small sparks. There should be an indication on the EICAS that the ignition is active.
  • With further increase in N2 rotation, fuel flow will be introduced. This will be verified on the EICAS. Once fuel flow is noted, it is important that the next stop happen fairly soon.
  • Light off! The fuel is lit by the ignition and now the fire burning in the hot section supplied by air from the compressor is producing thrust across the N2 and N1 turbines.
  • As the engine is producing thrust across on the N1 turbine, the N1 shaft is spinning the N1 fan and the EICAS will note this increase in N1 rotation. N1 and N2 rotation speeds increase.
  • Above a N2 threshold, bleed air valves supplying the the air turbine starter will close and the starter disengage. The igniters will turn off at some N2 threshold.
  • The engine will settle into a stable idle thrust setting.
What can go wrong?
  • Hung start
    • N2 fails to spin up sufficiently for fuel flow to be introduced.
    • Each start has a time limit and the start will be aborted.
  • No ignitors
    • Abort the start and switch igniters.
    • Give MX a call.
  • Failure to ignite
    • Fuel flow is introduced but light off has not occurred in a proper timeframe
    • Fuel is building up in the engine and if light off does occur, it can be damaging.
    • The start is aborted and dry motoring is performed to clear the engine.
  • ITT exceedence
    • There is usually a limitation in the inter-turbine temperature during engine start.
    • If this is exceeded the start must be aborted
    • This may require coordination with MX before another start is attempted.
  • The air turbine starter fails to disengage
    • This must be corrected before departing
    • In some engines, MX can correct this with the engine running.
  • The bleed air shutoff valve supplying the air turbine starter fails to close
    • This may require an engine shutdown to remedy
    • However, in some airplanes, this valve can be manually shut by MX with the engine running
    • Coordination with MX required.
  • Runaway N1 or N2
    • If the FADEC isn't managing fuel flow properly, the engine may not settle but continue to spin up.
    • Abort the start.
    • Coordinate with MX before attempting a restart.
What about starting the engine in the air?
If the engine suffers a flameout, an airborne restart may be attempted. These starts typically happen one of a few ways:
  • Crossbleed start
  • APU start
  • Windmilling start
The APU start is essentially the same process as above. The crossbleed start, which can also be done on the ground, merely substitutes a running engine at a high power setting to provide the bleed air for starting and is otherwise the same as above.
The interesting start is the windmilling start. The necessity for this means something bad has happened. To need a windmilling start, this means that there are no bleed air sources to supply the air turbine starter. This can mean that all engines are out and the APU is unavailable (BAD!), or merely that bleed valves to a shutdown engine have failed closed and are unable to be opened.
For the EMB-145 that I am familiar with, a windmilling start required descending at an airspeed between 260 KIAS and 320 KIAS and could not be attempted above FL250. In short, you hope that the mass flow through the engine is enough to spin the N2 compressor as the ATS would. With an N2 indication within the engines airstart envelope, you introduce spark and fuel and hope that the engine lights. In the worst case, if you too slow and unable to provide enough airflow prior to light off, the engine can quickly overtemp and be damaged. For this reason it is especially important to abort this kind of start as soon as an abnormality is detected.
share|improve this answer
Just a little gee whiz info, the RB211-22B and -524 as found on the L-1011 had an ENRICH position on the start switch to add a little fuel to get it going and prevent a hung start on cold days. This caused great and exciting white plumes of smoke. See this picture http://www.airliners.net/photo/Trans-World-Airlines/Lockheed-L-1011-385-1-15-Tr‌​iStar/0061484/L/ – Sports Racer Jul 23 '14 at 18:07
What is MX? Google says nothing... – Pavel Petrman Nov 17 '14 at 10:22
@PavelPetrman maintenance – casey Nov 27 '14 at 2:16
If you would like to know about jet engines, please read @casey's answer. It's very detailed and good.
There are some turbine engines which are started a different way. We are talking about turboprop or turboshaft engines. A famous example is the PT6 turbine, delivering power to many small turbine-powered propeller airplanes like Beachcraft's King Air series and Piper's Cheyenne and JetProp.
These engines consist of two parts, the gas generator and the free power turbine. The gas generator is pretty much a jet engine. It consists of an inlet, a compressor, an combustion chamber and a turbine. I don't know any turbo prop engine with a nozzle to create thrust, like a jet engine has one, but if one of you knows about it, I would be keen to read your comment. On a turboshaft engine the exhaust isn't at all used to generate thrust so some of them are even inverted (compressor at the rear part of the engine, but of cause still fed with air from an inlet directed forward). You maybe noticed that in some turboshaft driven aircraft the exhaust is very close to the prop - here's the reason.
The second component is a free power turbine, driven by the exhaust of the gas generator, driving the propeller via a reduction gear box (free power turbine speed > 30.000 RPM, prop speed < 3.000 RPM). In most engines these components are only held together by the engine case, that's why it's called free power turbine.
Now we all have a basic idea of this kind of engine and can talk about the start sequence. A so-called starter generator is connected to the gas generator. Basically it's an electric motor powered by a battery (or any other DC power source) used to crank the gas generator shaft. Once the engine is started this motor can be used as a generator delivering DC power. If you look at the principles of an electric motor and a DC generator you'll see that they are technically the same. You only need to change some connections. This is usually done by operating a three position rocker switch 'start-off-generator'.
The start sequence is pretty much the same as it is for a jet engine:
  • Crank the gas generator's shaft with the starter
  • At a specific rotation speed (usually 10-15%) add fuel
  • Monitor the engine parameters
  • Switch to the generator
Usually the free power turbine starts turning the propeller very soon after fuel is added, anyway some engines are equipped with a propeller brake preventing the free power turbine section from spinning. This is useful to operate the gas generator section only to obtain electric or hydraulic, sometimes pneumatic power - some kind of APU. Aerospaitiale's ATR series is a famous example. The called it "hotel mode".
Thanks for the compliment and broadening the answers to cover more than the turbofan in my answer. – casey Feb 27 '14 at 3:30
A side effect of starting a free-turbine like the PT-6 is that there is very little torque on the prop during start and idle. King Air pilots are occasionally pranked by passengers going under the wing and holding the prop during start. The pilot sees a running engine but zero prop RPM. You can hang on until about 20% power. Rather less fun with Twin Otters - obvious what's happening. – paul May 6 '14 at 8:18
Excellent answers so far. There are a couple other ways in which a jet engine can be started.
The F-16 has the engine connected to a gearbox with a special, high-speed-balanced shaft. There is a clutch where the shaft connects to the gearbox. Also attached to the gearbox is a smaller turbine known as a Jet Fuel Starter (JFS), approximately the size of a large watermelon, also with a clutch. The gearbox also has hydraulic pumps and generators.
To start the plane:
  1. the main engine is declutched from the gearbox
  2. the JFS is clutched to the gearbox
  3. hydraulic pressure is fed from an accumulator to a pump, causing it to work as a hydraulic motor, which turns the gearbox
  4. the turning gearbox spins up the JFS to the point that it reaches starting speed
  5. fuel is fed to the JFS, the ignition fires and it starts
  6. the JFS throttles up, producing about 200 horsepower
  7. when the JFS is running full tilt, the engine shaft's clutch engages
  8. the turning shaft rotates the main engine until it reaches start speed
  9. once the main engine reaches a particular speed, the JFS is declutched from the gearbox and shuts down
  10. the spinning engine brings the generators and hydraulics online, recharging the pressure in the accumulators for the next time it needs to start
In some respects, this is similar to a bulldozer or other heavy equipment. Many of them have a small "pony motor" with an electric starter, which then produces the power/torque combination necessary to start the main engine. Once the main engine is running, the pony motor declutches and shuts off.
Other, older aircraft, such as the F-100 Super Sabre, used a small, explosive charge (start cartridge, essentially a large blank). You'd install it into the engine. The pilot would electrically fire it into the exhaust turbine, which would spin up the engine enough (you hoped) to get the whole thing to start speed, then engage the fuel and ignition systems. If the cart failed to fire properly, you had to wait a certain period of time for it to cool off before you could remove it. You wouldn't want it going off on the ramp (possible presence of fuel vapors) or in your hands (ouch!).
When I see the picture of a JFS, a large watermelon doesn't exactly come into mind. – Farhan Feb 23 '15 at 14:54
Admittedly, it doesn't LOOK LIKE a large watermelon. But, for purposes of scale, that's about how large it is. And I have picked one up and carried it, much like a large watermelon. – Meower68 Feb 25 '15 at 16:46
I guess now it is my turn to add exotic ways to start a jet engine.
The Jumo 004 of the Me-262 and Ar-234 had a small piston engine in the central spike which was electrically started, but also could be hand-started by a mechanic. Did you ever note the hole in the middle of the spike, and the ring stuck in it (see the left picture below)?
Jumo-004 intake Riedel starter engine
The ring was attached to a string which could be used to start the piston engine (right picture). This could spool up the engine by itself up to 2000 RPM. At 500 - 1000 RPM the pilot would switch on the ignition. Now the starting combustion helped to spool up the engine further, until at 5000 RPM where the piston engine would decouple. Then the pilot could advance throttles slowly to 8700 RPM, the maximum.
What could go wrong? A lot:
  • The piston engine would not decouple.
  • Insufficient fuel flow, so the engine would not accelerate. In cold temperatures, the fuel pumps had to be switched on, but only up to 3000 RPM.
  • The ignition would not start soon enough. Then the rotating engine would supply fuel to the combustion chamber, where it would collect and be blown into the rear engine fairing. When the combustion started, the collected fuel would burn as well, resulting in an engine fire.
  • The pilot would advance the throttles too quickly. This would supply too much fuel to the combustion chamber and heat up the turbine above its limit. Only with the higher airflow near the design speed could the throttle be firewalled. -
The other starting procedure is that of the J-58s in the SR-71, which was remarkably similar. Only that the starter engine was a lot bigger and not part of the engine: It was a custom design of two tuned Buick 455 V-8s, coupled together on a cart and driving a vertical drive shaft that was driving the engine from a port under the engine nacelle. To start ignition, a special compound called triethylborane was injected, because the cold JP-7 (the special fuel for J-58s) would not ignite by itself. Once the engine could sustain itself, the cart was disengaged. Starter engine cart for SR-71s
The Buick engines would frequently fail and were later replaced by two Chevy big blocks. Also, the engines could be started with pressurized air. See this link for more.
What else could go wrong? That list is quite similar as well ...
So, you start the Jumo 004 with a pull, just like your lawn mower? That's fantastic! – FreeMan Feb 18 '15 at 18:11
@FreeMan: Yes, the Riedel engine in the Jumo was not too different from a lawn mower engine. – Peter Kämpf Feb 18 '15 at 18:59
discard
