Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Reading this page, a retired American Airlines pilot quotes:
We tell passengers what they need to know. We don’t tell them things that are going to scare the pants off them. So you’ll never hear me say, ‘Ladies and gentlemen, we just had an engine failure,’ even if that’s true.
Given this, how can an observant passenger sitting over wing (seeing most likely very little of the engine), determine if a flameout or shutdown has occurred from observation?
This is applicable to an aircraft not unlike the Boeing 737 (which I fly on often).
share|improve this question
As a passenger on a plane, the best thing you can do to enhance safety is to rest and be fit for your way from the airport - sorry but that's it. Feel as comfortable as you can in this seats rather than being stressed listening and looking for every detail. – Falk Feb 24 '14 at 4:58
Not all captains will keep this mum. Quote from the captain of British Airways Flight 9: "Ladies and gentlemen, this is your captain speaking. We have a small problem. All four engines have stopped. We are doing our damnedest to get them going again. I trust you are not in too much distress." (source: en.wikipedia.org/wiki/…) – Fred Larson Feb 24 '14 at 20:43
@FredLarson Well, that would be more of an extraordinary circumstance. I'm referring to the more common single-engine failure that is trained for and has a known plan of action to handle in most cases. – hexafraction Feb 24 '14 at 21:31
up vote 10 down vote accepted
Mainly by the soon to happen descent and landing, probably at a place you weren't expecting to go. :)
If you are seated behind the wing, you might be able to see smoke or flames coming out of the engine, but other times it will just quit with no visible indicaion, depending on the cause of the failure.
Sometimes (usually just after takeoff when the airplane is slow) it is obvious and you can tell by the change in the sound of the airplane (one side suddenly gets quiet or there might be a loud bang depending on why it failed), a sudden yaw in one direction (the nose pulls to one side), and an abrupt pitching down of the nose (done by the pilot to maintain flying speed).
Other times (like during a descent with plenty of speed and the engines at idle, or when the center engine of a three engine airplane fails) it can be hard for even the pilot to tell without looking at the instrumentation, so you probably won't notice it.
Another major clue would be when the seatbelt sign unexpectedly coming on, without an announcement or indication of turbulence, and the flight attendants suddenly putting things away and getting ready for landing, especially when you aren't close to your destination. Being briefed for an emergency landing is also a dead giveaway (no pun intended).
share|improve this answer
Failures still occur during level flight at cruising altitude; would those be detected similarly with the changes in sound, yaw, and a downward pitch? – hexafraction Feb 23 '14 at 2:35
Yes, but it wouldn't be as pronounced so it might not be noticeable from the cabin. They would have to start descending before very long though, so if you aren't anywhere close to your destination and the airplane start a descent it's a pretty good clue. – Lnafziger Feb 23 '14 at 2:41
Ingestion of foreign material into the engine could cause flames and sparks to spew out of it before it shuts down completely. – flyingfisch Feb 23 '14 at 3:06
@flyingfisch But, equally, ingestion of foreign material into the engine could cause flames and sparks to spew out of it before it continues to operate just as normal, right? – David Richerby Feb 23 '14 at 11:23
@DavidRicherby True, but loud bangs can also occur without the engine going out either. ;-) – flyingfisch Feb 23 '14 at 17:06
discard
