Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I observed that the cockpit windows on the commercial airliners actually open - good for a hot day while waiting on the airfield, I suppose. Is there a mechanism which prevents the window from being opened when airborne?
share|improve this question
up vote 15 down vote accepted
I'm sure that the cabin pressure difference prevents this at altitude when the cabin is pressurized, due that they often slide inwards and then to the side.
That being said, Boeing produced a video showing that it's no problem flying with an open window on the 737 if say it opens on takeoff. You can close it assuming it's not damaged or you can land with it. They also showed that the side window can be opened in flight in case for instance visibility is impaired through the main window, and while it hardly looks comfortable, it can be done. This assumes that the cabin is unpressurized.
The sort of thing you might be thinking about is a cooper vane, but I don't think any aircraft have those on the cockpit windows.
share|improve this answer
The QRH on the EMB-145 for both windscreens cracked and no visibility is to don the smoke goggles, open the window and stick your head outside to land. Glad I never got to try that one. – casey Feb 22 '14 at 21:58
Opening a cockpit window is also a step in some QRHs to remove smoke from the cockpit under certain conditions (i.e. If nothing else is working & it is getting too thick to see the instruments). Depressurizing is accomplished first, along with slowing down. The 2 airplanes I've seen that as a checklist branch, didn't list any max airspeed for it. YMMV. – Ralph J May 10 '15 at 18:06
What happens when you open the windows at Mach .8 -- cruising speed in a 747? – Sargun Dhillon Oct 2 '15 at 6:38
@SargunDhillon You can't. (re read the first sentence of the answer) – Antzi Oct 7 '15 at 16:44
It depends on the airplane, and there are speed limits on the ones that can be open. The windows on mine can be open up to 140 knots, but that is barely flying speed so it's really not practical.
Naturally, you can't be pressurized if you have a window open.
discard
