Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
It seems to me that takeoff weight is an important piece of data, and if one had weighing scales between the wheels and the aircraft body, one could precisely determine it. However, searching the internet, there seem to be no scales and cargo/fuel/passenger weight is estimated by adding up what is brought on board. Why aren't scales common? And are there any commercial airplanes that have them?
share|improve this question
up vote 18 down vote accepted
Yes, such a system exists. It was developed during the sixties and installed as an option on the Boeing 707-300 freight aircraft. Other aircraft that had a similar (optional) system include the L1011 and Boeing 747.
It is mostly found on freight aircraft because they have a less predictable load distribution (centre of gravity) than passenger aircraft.
The reason they are not common is that they add cost in the form of installation, weight and maintenance. While quite accurate when in good condition, the reliability of the weighing systems used to be poor, which probably contributed to the fact they never became wide spread.
Because crew are commonly operating on several aircraft types these days that have take-off weights of more than 100 metric tonne difference (e.g. A330 and A340, B747-400 and B747-8) there is an increase in take-off weight confusion related incidents. This, combined with the fact that systems are becoming more reliable, makes it likely that these weighing systems will be used more in the future.
share|improve this answer
It might be interesting to note that at least Airbus (A320 and all newer models) can calculate weight from aerodynamic performance once airborne and will issue warning if it differs from the value set in FMS by more than specified tolerance (4 t for A320). It is however somewhat late if you are overweight. – Jan Hudec Feb 24 '14 at 7:04
The C-130 has such a system, and I'm pretty sure the C-5 does also. – Jim In Texas Feb 26 '14 at 19:55
The first link looks dead to me – raptortech97 Feb 25 '15 at 21:47
@raptortech97 link fixed – DeltaLima Feb 25 '15 at 22:03
@raptortech97 Damit Jim, I'm a doctor not a pilot! /late to the party :( – FreeMan Feb 25 '15 at 22:25
Simple answer
For one thing it will not work because of wind: Once you put wings on a fuselage, you will need to bring that airplane into an enclosed hangar for the scales be accurate.
Mind you, this is exactly what being is done whenever an airplane is being weighted for mass & balance purposes, about every three years: enclosed hangar and massive scales under the gears. Doing it on a daily basis in an already crowded airport is not an option.
Complex answer
What you really need to know for your a/c is mass, not weight. Also, you'd want to know the mass distribution inside the a/c, not just to calculate the center of gravity (which a scale can also do), but also to make sure that load limits are respected in each section (which a scale will not do). Adding and removing numbers on a load sheet works pretty good for this purpose, as does estimating passenger weights and luggage as an average, although there are talks that those averages need to be increased lately.
Even if you eventually found a way to scale each airplane before takeoff, in a controlled environment, the extra costs will never be justified since you basically improved on something that works.
The FMS could calculate the real value. The lift is proportional to the pitot tube reading and angle of attack and therefore known. In fact Airbus systems can check the weight from these values when airborne. – Jan Hudec Feb 24 '14 at 7:06
Even in older jet transports that lack an FMS, you can go into the tables and see what the weight is for a given altitude/mach/temperature/fuel flow. Of course, this is once you are in the air at which point the fact that you are 30,000 lbs heavier than you thought you were at takeoff is of little value other than to alert you to the fact that you're probably going to have to stop for fuel before reaching your destination. – Terry Feb 24 '14 at 9:49
@JanHudec That assumes that the wind is uniform across the whole aircraft. But a stationary aircraft (especially parked near a building) isn't likely to experience anything like uniform wind. – David Richerby Feb 26 '15 at 15:06
I doubt that wind is an issue when for such a system. There'd have to be a constant wind (over a longer period of time) that's strong enough to significantly change the weight measurement. – jjack Feb 27 '15 at 19:48
discard
