Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I frequently hear the tower instruction
Report a two mile base for runway 5
What is the intention of that instruction? I realize that under these circumstances that we're not looking for pinpoint precision, but still it would be nice to know.
For the record, I'm not asking what a base is (or the fact that "left" is implicit), but what two miles are we talking about? Two miles straight line distance from the threshold? A base to a two mile final? On the base leg, two miles from the centerline? (I'm pretty sure the last one isn't it, but hey, I've been wrong before)
share|improve this question
up vote 6 down vote accepted
They basically ask you to report it as a "memory jogger" for themselves so that they can do something when you call in (like clear you to land).
A standard airport traffic pattern is described in Chapter 7 of the Airplane Flying Handbook as:
The downwind leg is a course flown parallel to the landing runway, but in a direction opposite to the intended landing direction. This leg should be approximately 1/2 to 1 mile out from the landing runway, and at the specified traffic pattern altitude. During this leg, the before landing check should be completed and the landing gear extended if retractable. Pattern altitude should be maintained until abeam the approach end of the landing runway. At this point, power should be reduced and a descent begun. The downwind leg continues past a point abeam the approach end of the runway to a point approximately 45° from the approach end of the runway, and a medium bank turn is made onto the base leg.
It looks like this:
AIM Traffic Pattern
When the tower asks you to fly a two mile pattern, they want you to fly a pattern that has the downwind leg 2 miles out from the runway instead of the 1/2 to 1 mile that is normal. The base leg would still be turned when 45° from the approach end of the runway.
In this case, you are either:
  1. Doing pattern work in which case you fly the two mile wide pattern and should report turning base, or
  2. Approaching the airport and the controller would like you to enter the two mile wide pattern on the base leg. You should report the point where you would have normally turned onto the base leg if you were flying the entire pattern (45° to the runway). This would actually be both of your last two scenarios above: Established on the base leg, two miles prior to intercepting a two mile final (which for fun would actually be 2.83 miles from the runway).
share|improve this answer
I've actually always been told the opposite - a "2 mile base" means you are on the base leg that would put you onto a 2 mile final after your base-to-final turn. – egid Feb 20 '14 at 23:52
@egid That isn't the opposite of what I said, it is exactly what I said (only much shorter, lol). – Lnafziger Feb 20 '14 at 23:53
Ah, yeah, rereading I see that. You seem to imply that it also requires a wider pattern by mentioning the 45° turn. – egid Feb 20 '14 at 23:54
@Qantas94Heavy Umm, that is what I'm saying.... 2 miles from the runway (and parallel to it, which is what the downwind leg would be) would also be 2 miles from the extended runway centerline. – Lnafziger Feb 21 '14 at 0:48
@Lnafziger what math? well, you know: 2x1=2 – Radu094 Feb 21 '14 at 11:39
discard
