Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm wondering if it's possible to forward slip a large commercial aircraft, like the A320 or even B777, and if so: is effective or useful, since most small aircraft which I gather do it have no spoilers for instance which large aircraft do?
share|improve this question
up vote 11 down vote accepted
It's it possible? Yes, you would do it the same way as in any other airplane.
Is it effective? Yes, just look at all of the fuselage area that is exposed to the relative wind.
Is it useful? Not really. With all of the other drag devices, you shouldn't really need it.
Is it recommended? You would have to check the AFM. I looked in the A320 Flight Crew Training Manual and there is no limitation against it, but if you need to slip then that's a strong indication of poor planning and an unstabilized approach which would require a go around. Even at higher altitudes, it isn't very comfortable for the passengers!
share|improve this answer
Its useful if you're heading into Gimli hot, high, and dry :) – falstro Feb 18 '14 at 15:12
@roe i'm not sure he had the hydraulics to get the spoilers out though with two engines out.... – MikeFoxtrot Feb 18 '14 at 15:52
@roe In a "glider" like that, all bets are off and you do what you have to do whether or not it is stabilized or is an approved maneuver! – Lnafziger Feb 18 '14 at 19:44
One of my friends was a heavy pilot for USAFA and during his first flight for the airlines in a 737 he forgot he had 100s of passengers and almost did a slip out of habit! On a similar note, I would have to disagree, because it is very useful to the air force with large cargo jets, potentially carrying much more than a commercial plane. – Sponge Bob Feb 19 '14 at 0:31
discard
