Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Unfortunately, my skills and understanding of radar and the like are very limited, but if somebody could enlighten me why there is no such thing as a dual bird/weather radar to switch to?
I've understood there there have been some (successful) attempts with ground station. It would add weight, but i'd guess that perhaps would be offset for some time by a single ruined engine.
share|improve this question
As an aside, putting the radar on would be easy. Actually avoiding the birds once you know where they are would still be really hard – egid Feb 14 '14 at 17:51
Most big planes spend most of their time flying far above altitudes where birds are found. So you're talking about hauling around this radar on every flight, but only using it for a few minutes on takeoff and landing. Thats a very bad weight/utility tradeoff. – abelenky Feb 14 '14 at 18:32
@abelenky Birds can be found pretty high. :-) But I do agree that a radar would be impractical beyond takeoff or landing. And those operations are better suited to airport systems. – Shawn Feb 14 '14 at 19:04
I have "heard" that turning the weather radar on can cause birds to get out of your way, but I haven't seen any actual evidence to back it up. I turn it on just in case it helps though since there is very little downside. :) – Lnafziger Feb 14 '14 at 19:42
@abelenky, as Shawn said some birds are indeed capable of flying very high however the largest risk of a bird strike is during takeoff and landing where birds are firstly more likely to be but also there is little to no chance of maneuvering -especially in an emergency situation. (and Lnafziger, dont let certain groups catch you saying/doing that) – Matthew Peters Feb 6 '15 at 18:30
up vote 12 down vote accepted
There really is no such thing as "bird radar". Radar comes in a few frequency bands that have certain advantages depending on the distance, resolution and attenuation you need out of it. The band isn't the only factor here as the band will dictate what size dish you need and your aircraft nosecone will but a distinct upper limit on that. Weather radar is geared toward detecting rain drops and anything bigger than rain (hail, bugs, birds, etc) with reasonable distance and attenuation features (you want to penetrate into a storm). Birds will show up on this radar, though depending on smoothing and processing algorithms you may need a flock of them before they get drawn on the radar, at which point they'll look like some rain. A radar optimized to detect bird sized objects would probably use a wavelength that did not let you see things as small as rain drops and small hail.
Some other things to keep in mind are that the radar is not always on, and it should be off on the ground except during takeoff when needed. The reason for this is that you do not want to be putting radar energy into people, and they tend to be in the way on the ground. We only turned the radar on for takeoff when there was significant weather around the field and wanted to be prepared for requesting diversions. Aircraft radar tilt can also be adjusted, so we wouldn't be looking at birds in front of us, but clouds above and in front of us.
Wit that said, our SOP on fields with known heavy bird activity was to takeoff with the radar on and pointed forward because someone had the idea that the birds didn't like being in the radar beam. I have no sources to back that idea up, but it was written into our FOM.
Now assume you can takeoff and see a flock of birds on the radar. Do you have enough time to do anything about it? If so, what do you do, some maneuver away from them or do you turn into them in hops they take the evasive action?
Now back to the title question: Why aren't bird radars in the nose cone?
  • The weather radar can see birds, it would be redundant.
  • A bird radar (optimized for birds) would not be good at seeing weather, so where would the weather radar be placed?
  • In a real situation, what would a bird radar enable you to do with a positive detection with the time you have to react to it? Probably not much.
  • Weather is a much more common threat than flocks of birds, so if you can only have 1 radar system, you want the weather radar.
share|improve this answer
The fact about attenuation makes sense. It would be very difficult to single out the birds from other stuff, and benefit in general would be marginal. the birds getting scared by weather radar sounds like something for mythbusters :) thanks for the answer – MikeFoxtrot Feb 15 '14 at 18:23
Supposedly the MiG-25 had the ultimate solution. Its radar was so powerful it'd kill any bird in its path, clearing itself a way through the flock :) But it also killed people, so it was decided to limit its use to above a certain altitude to prevent accidents. – jwenting Feb 19 '14 at 12:52
Wow, that's quite the radar. Did it operate on 2.4 GHz and boil the bird or something? It seems like you'd have to be really close (or have a very, very focused beam) to concentrate that much power onto something the size of a bird, since received power is inversely proportional to the square of the distance from the transmitter. Unless, of course, you're using a laser. I'm guessing that the YAL-1 could take out birds pretty easily, though. :) That would be fun to watch, as long as you didn't accidentally hit the ground. – reirab Aug 28 '14 at 19:23
In a real situation, what would a bird radar enable you to do with a positive detection with the time you have to react to it? Maybe throttle down the engines for a few seconds to avoid sucking in the birds. – DrZ214 Aug 13 '15 at 0:12
I don't know that a radar would provide enough of a warning anyway, if it could even see a single bird. And all it takes is one. The majority of birdstrikes happen near the ground, and the things I've seen have tended to be more to keep birds away from airplanes rather than trying to dodge them. They use cannons/noise-makers at many airfields and other means to keep birds away from low aircraft. And I've heard that the spiral painting on the compressor cones of many big jet engines, in addition to giving a visual indication that the engine is running, has a side benefit that, to a bird, it looks like the eyes of a predator and tends to scare the birds away from the engines. There have been mixed studies on the efficacy of that claim, but I don't know that any scientific research has been done to give a real yes or no. Boeing will claim that it doesn't matter. JAL claims that they had fewer birdstrikes on aircraft with painted spinners. I don't really know if it works or not.
In my experience, you aren't going to see-and-avoid most birds. You're simply moving too fast for either of you to get out of the way. I quit flying with only a few thousand hours, and I've hit several birds. And I don't know very many pilots who haven't either hit one or had a near miss. I've even been hit by a goose in my door when I while I was teaching in a 152, one of the few times that I can actually say the bird hit me and not the other way around.
The best way to keep from hitting birds is to try to avoid areas where birds are known to be flying, especially during migratory seasons. If you hear reports of a flock of birds at your airport, use a lot of caution. And report them if you see them. Try to minimize low flying. In most small craft, it's unavoidable. Your normal operating altitude is fairly low and right within the area that birds tend to fly. In bigger aircraft, try not to dally at lower altitudes, if you can help it. Climb to your altitude And if you're low to the ground (landing or taking off) don't put the aircraft in danger by trying to dodge birds. And every takeoff should include an idea of what you're going to do if you do hit birds.
From http://www.birdstrike.org/
"About 41% of reported strikes with civil aircraft in USA occur while the aircraft is on the ground during take-off or landing and about 75% of strikes occur at less than 500 feet above ground level (AGL). However, over 4,200 strikes involving civil aircraft at heights above 4,500 feet AGL were reported from 1990-2013 in the USA and over 430 of these were at more than 10,500 feet. The world height record for a bird strike is 37,000 feet (Griffon vulture off the coast of Africa)."
This first paragraph has some good points, but cites no references and, overall, the answer digresses from the point of the question which was specifically: why aren't there bird radars? Other methods of keeping birds away, while interesting, isn't really what was being asked. – Bret Copeland Feb 14 '14 at 19:37
Wow, 37000 ft bird strike. That is awesome. I mean, not the bird strike, but the fact that there are birds flying at 37000 ft. – falstro Feb 15 '14 at 10:19
@Bret Copeland I'm not sure what references you were looking for me to cite or how my answer digressed from the question. My answer was primarily based on my own experience, but I did provide a citation to birdstrike.org to back up my statement that most bird strikes happen near the ground. My answer demonstrated why a bird radar was impractical on an airplane and how there are much better resources that require little more than looking out the window and using the radio. The justification for a bird radar just isn't there. It wouldn't do you much good. – Shawn Feb 17 '14 at 21:25
The weight of the bird radar would be trivial and it could easily fit in the nose cone; they aren't that big. They don't have to look nearly as far out as weather radar, All they have to do is indicate altitude and direction. Aircraft can easily avoid collision by changing altitude. They only have to miss the bird by being a few feet higher or lower, and birds oftentimes fly level at the same altitude, especially when migrating. The computer could be programmed to avoid collision by adjusting the angle of ascent or descent.
Hi Andrew, welcome to Aviation.SE. Your post here does not really answer the question, it rather says it could be done, but doesn't answer the OP's question on why it is not done. Check out the Help Center on proper answers. – SentryRaven Jun 26 '15 at 13:08
discard
