Take the 2-minute tour ×
There are a couple of American military aircraft (the retired F-14 and the B-1 come to mind immediately), that have variable swept wings. I know that they keep the wings full out (roughly perpendicular to the body) during take off and landing, and they have the wings swept back for high speed flight.
But I've never really understood why? I assume that at lower speeds the wings out configuration creates more lift. But, why does sweeping the wings back help at high speed?
For bonus points: how does the performance gain make up for the cost in weight and complexity created by having a variable swept wing? Or perhaps there isn't much of a gain and that's why most military aircraft don't have variable sweep?
share|improve this question
I can't write up a whole answer right now, but basically a wing with higher sweep has less drag at high speeds. Unfortunately, it doesn't produce enough lift at slower airspeeds so they would have to land extremely fast if it stayed that way. This design allows them to get the "best of both worlds". –  Lnafziger Feb 13 '14 at 20:58
Ah, okay, I can see that on a basic level. I'd love to see your whole answer when you have a chance. Details are always appreciated :). –  Jay Carr Feb 13 '14 at 20:59
Study here. Smithsonian article here –  SSumner Feb 13 '14 at 21:33
I was hoping for something slightly less technical than the first article (though I'll give it a try) and the second link does not appear to be working. Still, that does seem to have it well covered... –  Jay Carr Feb 13 '14 at 21:48
Another worthwhile link: en.wikipedia.org/wiki/Swept_wing –  barit1 Dec 15 '14 at 20:39
up vote 10 down vote accepted
By sweeping wing backwards, you essentially make the air 'see' another airfoil.
Look at these two diagrams:
sweep
sweep
When the air meets the wing, it travels along $V$. This 'seen' airfoil is a lot thinner than $V1$ (which is perpendicular to the leading edge). As the aircraft experiences less pressure, the aircraft experiences less drag. However, this also reduces the velocity of the air. This is good if you're looking to delay things such as shockwaves as the air goes supersonic, since spreading the force out more delays this effect and the flow separation which comes with it.
shockwave
Unfortunately, for all the advantages, It would have a very high landing speed. So the wings are swept forward, the aircraft has a more effective aerofoil for lower speeds, and the minimum airspeed decreases correspondingly. There is now more drag, but also more lift which you need for the slower speed.
wings
Wikipedia puts this nicely in not all too-complex terms:
If we were to begin to slide the wing sideways (spanwise), the sideways motion of the wing relative to the air would be added to the previously perpendicular airflow, resulting in an airflow over the wing at an angle to the leading edge. This angle results in airflow traveling a greater distance from leading edge to trailing edge, and thus the air pressure is distributed over a greater distance (and consequently lessened at any particular point on the surface).
This scenario is identical to the airflow experienced by a swept wing as it travels through the air. The airflow over a swept wing encounters the wing at an angle. That angle can be broken down into two vectors, one perpendicular to the wing, and one parallel to the wing. The flow parallel to the wing has no effect on it, and since the perpendicular vector is shorter (meaning slower) than the actual airflow, it consequently exerts less pressure on the wing. In other words, the wing experiences airflow that is slower - and at lower pressures - than the actual speed of the aircraft. One of the factors that must be taken into account when designing a high-speed wing is compressibility, which is the effect that acts upon a wing as it approaches and passes through the speed of sound. The significant negative effects of compressibility made it a prime issue with aeronautical engineers. Sweep theory helps mitigate the effects of compressibility in transonic and supersonic aircraft because of the reduced pressures. This allows the mach number of an aircraft to be higher than that actually experienced by the wing.
Is there a performance gain? Depends on your definition:
Having fixed swept wings would imply that:
  • The landing speed might be unacceptably high, and with that, long runways would be required.
  • You could design a fast and light aircraft.Take the F104 Starfighter for example, which had thin, short wings for the same effect but couldn't move them, and was extremely dangerous at slow speeds.
Having variable wings:
  • The F14 was intended for carrier operations, where you would want a slow landing speed. Making an aircraft go that fast would probably have been impossible otherwise. It was also designed for long range operations, adding weight of fuel.
  • Adds weight and mechanical complexity to the airframe, which increases maintenance cost and fuel burn.
If I understand it correctly, today aircraft today rely more on system such as high-lift devices like for instance slats and flaps.
share|improve this answer
Perfect, great answer @Manfred. –  Jay Carr Feb 14 '14 at 2:48
Unsweeping the wings does not actually reduce the stall speed that much, because stall speed depends on wing area and that only changes a little. But it significantly reduces induced drag, because that depends on wing span and that changes significantly. –  Jan Hudec Feb 14 '14 at 20:08
VG also adds size, as you lose internal space to the wing mechanism, and need larger engines and fuel tanks to get the same performance (all of which means you need more power and fuel again as your weight goes up even more). Hence VG aircraft have tended to be rather large (and AFAIK all except the MiG-23/7 were twin or four engined). –  jwenting Feb 19 '14 at 13:07
All answers so far focus on the lower drag of swept wings at high subsonic Mach numbers. But there is more to sweeping wings:
The main benefit for the B-1 (which was supposed to penetrate air defense at low altitude) is the lower lift slope of a swept wing. This translates into much better riding qualities in turbulent air. If the plane hits an updraft at high speed and in the high density air near the ground, the lift increase is massive if the wing is unswept. Sweeping it reduces the lift increase with the cosine of the sweep angle, and a gust which would have produced 4 g with the unswept wing produces only 2 g with 60° sweep.
The other benefit is the possibility to use high-lift devices on the wing. The trailing edge comes forward and out for the landing configuration, so the pitching moment of the flaps can be controlled by the elevator and more air can be used for lift generation. Trailing edge flaps on a delta wing (which is basically the swept-back configuration), on the other hand, do not work well at all. This is helpful both for landing on a carrier and for taking off for a long-range bombing mission.
Swing wings were something of a fad in the 1960s, and they have lost a lot of appeal lately. The Panavia Tornado would have been a better plane for most of it's missions with a fixed wing. But it just happened that three of the lead engineers had patents on swing wings ...
So, what kinds of missions are swept wings really useful for then? You make it sound like there's not really enough of an advantage to justify ever really using them? –  Jay Carr Aug 4 '14 at 15:33
@Jay Carr: Did you want to say "swing wings"? Wing sweep is immensely helpful in order to fly close to Mach 1, above Mach 1 with a subsonic leading edge, for low gust sensitivity and for reaching high angles of attack in a controlled way. Swing wings, on the other side, are helpful only in a few special cases and in most applications did not fulfill the initial targets of the designers. –  Peter Kämpf Aug 4 '14 at 15:58
lol, yes, I meant swing wings, sorry. So there's no real practical application? At least not one that can't be done a bit easier by other means? –  Jay Carr Aug 4 '14 at 16:01
@Jay Carr: I hate generalizations, so I will not use one here. But in most cases, thinking a little harder how to make things more simple pays off. A swing wing will immediately solve a lot of problems, but will introduce different ones, first of all more mass, more demands on systems and more internal structure. Making the aircraft smaller and simpler might save the need for the high-lift forward wing sweep configuration. –  Peter Kämpf Aug 4 '14 at 16:07
Swing Wings were useful, and are still useful. Its just that the increasingly higher speeds are not needed by aircraft anymore. Back in early 1960s, the main nuclear weapons delivery platform was bombers. Which needed to be intercepted, and that required speed. Bomber speeds also kept increasing, so that required even higher speed for interceptors. Intercepting or not intercepting was the difference in 'winning' a nuclear war. Hence the swing wings for fuel efficiency for low speeds (cruise) and shorter take off/landing AND high supersonic speed..... But with the ICBMs, that need was no more. –  unity100 Jan 11 at 19:10
Well the problem is not only the lift created but also the drag. At high speed transonic and hypersonic, the drag created by straight wings is much larger than the drag created by swept wings (or even better by delta wings). This mainly comes from the fact that due to the sweep angle the effective Mach number the one perpendicular to the leading edge of the wing is lower than the Mach number of the aircraft. This helps a lot in reducing the drag due to chocks and thus sustain very high speed with not too much drag and hence thrust required. So far so good, but...
Delta wings and at smaller degree swept wings at low speed present what is called a spanwise flow. This is the fact the the flow is pushed in the spanwise direction from the root to the tip. This increases the distance of the flow over the wing and thus the boundary layer thickness at the trailing edge (compared to straight wings). This has the immediate effect to lower the stall angle or at least the angle at which the first separation appears. This also reduces the lift generated when the aircraft is flying at a non negligible angle of attack. This is particularly the case for take of and landing for which the straight wings yield better performances.
To sustain the aircraft in the air with a smaller angle of attack means to fly faster and this is obviously not is looked for during take off and landing. This is why it is beneficial to use variable swept wings for some military aircraft which need to take off or land on short distances and then needs a smaller take off and landing speed.
discard
