Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Air Force One is obviously a big deal. We close terminals and implement other seemingly crazy safeguards against terrorist attacks while the president is en-route to an airport.
How does ATC protect the president whilst in the air?
  1. I have heard of TFRs for "VIP in the area" reasons — is that for AF1?
  2. I am guessing that the aircraft identification is blocked, but wouldn't they still need to have the transponder on for TCAS?
Specifically, the Wikipedia page on Air Force One has the following quote:
Air traffic controllers gave Air Force One an ominous warning that a passenger jet was close to Air Force One and was unresponsive to calls. "As we got over Gainesville, Fla., we got the word from Jacksonville Center. They said, 'Air Force One you have traffic behind you and basically above you that is descending into you, we are not in contact with them – they have shut their responder off.' And at that time it kind of led us to believe maybe someone was coming into us in Sarasota, they saw us take off, they just stayed high and are following us at this point. We had no idea what the capabilities of the terrorists were at that point."
Does having the transponder on just paint a huge target on the radar for terrorists?
share|improve this question
Well primarily, ATC doesn't. I'm sure they'll vector aircraft away, but military F-16s are a much better protection – SSumner Feb 12 '14 at 3:49
the time that Bush went to his troops in a covert mission AF1 adopted another call code and disguised itself as a smaller plane, but for most other applications any time the president is on board an airplane it automatically gets the AF1 call code (even if it is a tiny cessna). If the new president is making his oath and the old one is still flying then they'll need to request a new call code. – ratchet freak Feb 12 '14 at 10:04
Aircraft are always an easy target because they are so delicate. At least when they are low to the ground anyway. As far as TFRs law-abiding pilots ATC tells us to turn left, we turn left. Terrorists don't obey laws so the TFR is kind of silly in that respect although I suppose it does help keep the number of overall radar 'targets' in the area down to a minimum. – p1l0t Feb 12 '14 at 13:58
ratchet freak, this is not quite true. For example, when the President is on the Marine helicopters, the call sign is "Marine One". the first word here indicates the "owner" of the aircraft: Air Force, Navy, Marine, etc. For a civilian owned aircraft, the call sign is "Executive One". – Skip Miller Feb 12 '14 at 15:19
@SkipMiller I'd like to see what happens if the AF takes out a wet lease on an aircraft to transport the president. What would its callsign be? It's not an AF owned aircraft, but technically AF operated ;) – jwenting Feb 24 '14 at 7:37
up vote 11 down vote accepted
Whenever Air Force 1 takes off or lands, the FAA establishes a 'Temporary Flight Restriction'.
Essentially this is a big 'upside down wedding cake' of airspace in which Air Traffic Control exercises very tight control of any aircraft operating in the TFR. Any traffic entering the TFR without prior approval, or any aircraft deviating from ATC instructions will be intercepted by military aircraft.
When President Obama takes a bus trip the FAA establishes a TFR over the bus, that moves so as to stay over the bus as he rolls along!
Wikipedia has a good article on TFRs.
share|improve this answer
"upside down wedding cake" - Every presidential TFR I've seen is always to the surface. – Steve Kuo Jul 20 '14 at 0:53
discard
