When the wing of an aircraft is located above the fuselage, the aircraft is generally considered more stable.
When the wing of an aircraft is located below the majority of the fuselage, the aircraft is generally considered more acrobatic.
Why then, do large commercial jumbojets generally have their wings located towards the center (from top to bottom) or bottom of the aircraft? On first glance, this design seems odd since one of their primary goals is stability in flight.
    $\begingroup$ Because there is a thing like being too stable $\endgroup$ Jun 7, 2015 at 19:17
    $\begingroup$ @ratchetfreak Can you expand on that comment into an answer? In doing so, can you explain why it works for small aircraft but not larger ones? $\endgroup$ Jun 7, 2015 at 19:19
  • $\begingroup$ There are regulations about how fast an airplane must be able to roll a too stable plane will not be able to do so. $\endgroup$ Jun 7, 2015 at 19:24
    $\begingroup$ Wing position is secondary for roll speed. Inertia, roll damping and aileron size are the driving factors. $\endgroup$ Jun 8, 2015 at 9:53
First of all, I do not agree with your assessment: The wing of large commercial aircraft is clearly below the fuselage, to allow the cabin not to become divided by the wing spar. The A380 would have better aerodynamics if the designers had interrupted the lower cabin by the wing spar, but the airlines did not want this at all. Please look at the picture below: I hope you will agree that the wing is clearly below the majority of the fuselage. Why this is done has been answered here and here.
Air France A380 during approach
Large commercial aircraft have low wings to stow away their long landing gears. Long gears make it possible to stretch the fuselage and still be able to rotate during take-off. Large high-wing aircraft with their low fuselage position are easier to load and unload, at the price that the fuselage taper has to start shortly aft of the landing gear, so no stretching is possible.
A mid-wing design is common to aerobatic aircraft. For ideal roll handling, all parts should be aligned along a single axis, and doing this complicates fuselage design. Only for aerobatic aircraft the benefits outweigh the disadvantages. See the picture of an Extra 300 below:
Patty Wagstaff in her Extra 300 S
A high wing is selected when the gear height should be low for loading and unloading, when the downward field of view of the pilot should not be restricted (think parasol design in WW I), when the wing should have more ground clearance during landing (think gliders) or when the wing is meant to pivot horizontally (see picture below for an example). Note that the combination of a high wing and wing sweep will produce too much sideslip stability and needs to be corrected with anhedral. All three (sweep, wing position and anhedral) change with angle of attack, and the combination will still have too much or too little stability away from the design angle of attack.
NASA AD-1 research aircraft in flight
As Jan Hudec pointed out, pitch and yaw stability depend mostly on tail size and location, and even roll stability is affected by more than the wing's location. The location is a compromise of many, sometimes diverging parameters, and stability is only a small part of it.
High-wings increase stability in roll. It does not significantly affect stability in pitch and yaw; for those appropriate tail design is needed.
Why then, do large commercial jumbojets generally have their wings located towards the center of the aircraft (from top to bottom)?
It is more efficient.
No, it isn't.
Most important is stability in pitch, because pitch is related to speed and energy management. But that just needs appropriate horizontal stabilizer and high or low wing does not matter. Stability in yaw is also important, but that is achieved by appropriate vertical stabilizer, again with little difference between high and low wing.
But in roll, the aircraft must not be stable too much. High roll stability provokes dutch roll oscillation and reduces manoeuvrability. So aircraft are designed to be only very slightly stable in roll.
And even for roll stability both low and high wing designs can be relatively easily adjusted for the right amount. Roll stability can be increased by adding dihedral and decreased by adding anhedral as needed.
There are regulations regarding
  1. Pitch Rate
  2. Roll Rate
  3. Yaw Rate
Out of this, the regulations regarding roll rate are as under:
§23.157 Rate of roll.
(a) Takeoff. It must be possible, using a favorable combination of controls, to roll the airplane from a steady 30-degree banked turn through an angle of 60 degrees, so as to reverse the direction of the turn within:
  1. For an airplane of 6,000 pounds or less maximum weight, 5 seconds from initiation of roll; and
  2. For an airplane of over 6,000 pounds maximum weight, W+5001,300 seconds, but not more than 10 seconds, where W is the weight in pounds.
(b) The requirement of paragraph (a) of this section must be met when rolling the airplane in each direction with—
  1. Flaps in the takeoff position;
  2. Landing gear retracted;
  3. For a single-engine airplane, at maximum takeoff power; and for a multiengine airplane with the critical engine inoperative and the propeller in the minimum drag position, and the other engines at maximum takeoff power; and
  4. The airplane trimmed at a speed equal to the greater of 1.2VS1 or 1.1VMC, or as nearly as possible in trim for straight flight.
(c) Approach. It must be possible, using a favorable combination of controls, to roll the airplane from a steady 30-degree banked turn through an angle of 60 degrees, so as to reverse the direction of the turn within:
  1. For an airplane of 6,000 pounds or less maximum weight, 4 seconds from initiation of roll; and
  2. For an airplane of over 6,000 pounds maximum weight, W+2,8002,200 seconds, but not more than 7 seconds, where W is the weight in pounds.
(d) The requirement of paragraph (c) of this section must be met when rolling the airplane in each direction in the following conditions—
  1. Flaps in the landing position(s);
  2. Landing gear extended;
  3. All engines operating at the power for a 3 degree approach; and
  4. The airplane trimmed at VREF.
Hence, a too stable plane cannot achieve such rates at the prescribed mach number, and the control surface deflection. So the wing position is kept so as to meet this requirement. Moreover, if you think that such configuration of the wing would make the airplane inherently unstable, the modern computers on the plane with proper feedback systems take care of such a thing.
  • $\begingroup$ Can you clarify W+5001,300 seconds, from section (a)2, and W+2,8002,200 seconds from section (c)2. It appears to me to be poor formatting, either in the source or from the copy/paste, but I'm not certain. I've not been able to make sense of it in any way. $\endgroup$
    – FreeMan
    Jun 8, 2015 at 12:44
  • $\begingroup$ @FreeMan I believe they're meant to read (W + 500) / 1,300 and (W + 2,800) / 2,200 respectively (probably originally printed as fractions). They're consistent with an obvious way the formatting could have been mangled, and they make the functions continuous at the 6000 lb breakpoint. $\endgroup$
    – hobbs
    Sep 7, 2016 at 5:13
