Take the 2-minute tour ×
For a Private Pilot License in USA, what happens when a student takes his/her checkride? I want to know the sequence of events. According to my knowledge, which is sort of vague, things proceed as follows:
  1. Student takes an oral and written exam (not sure if it's on the same day of checkride or prior to that).
  2. Examiner asks student to plan a cross country flight.
  3. Examiner and students go for this planned cross country flight.
  4. Examiner may or may not cancel this plan and asks student to go back (does not effect result).
  5. At the end, examiner tells the student if he/she has passed or not.
What I don't know is:
  1. How much of the above is accurate?
  2. And how long does it take?
  3. How emergency procedures are created and tested?
  4. Who makes sure that the weather is suitable for flying?
  5. What if checkride has to be cancelled for reasons not controlled by student?
  6. What else did I miss?
share|improve this question
4 Answers 4
up vote 14 down vote accepted
That's pretty much the checkride in a nutshell - for all the details on what's expected you should refer to the FAA Practical Test Standards for the rating you're pursuing.
Before your checkride
At some point before your checkride you must take a "knowledge test" (the "written exam") - you must pass that exam in order to qualify to take the checkride (the "practical test").
The results of the knowledge test are good for 2 years.
You will also receive instruction from your CFI specifically for "checkride preparation" (you must have 3 hours of this instruction within the 60 days prior to taking your checkride).
Usually your instructor or school will arrange for an examiner. Be sure to find out where he wants you to plan your cross-country trip to, and also ask for his weight (so you can do the weight and balance calculations), and the cost of the checkride (so you can have the money ready).
The Oral Exam
The day of your checkride1 you'll probably spend at least as much time on the ground with the examiner than in the air.
You'll start with the practicalities: making sure your 8710 is in order, verifying your eligibility, and paying the examiner.
Next, you'll go over your logbook with the examiner (do everyone a favor and bookmark all the things they'll need to see), and then you'll be given a thorough oral grilling2 by the examiner.
You'll be expected to know your aircraft's V speeds, it's useful load, and its fuel capacity (in gallons and hours), and you might have to be able to answer intelligently based on a scenario, like "supposed you want to take 3 members of your football team's lineup on a 300 mile trip..."
There will also be scenario-based regulatory questions ("You're taking your friends for a flight in the spring, but you haven't been in an airplane all winter. What do you need in order to be able to conduct this flight?")
You will also be expected to plan (or have planned, depending on the examiner3) a cross-country flight (including a weight and balance calculation using the examiner's weight, and possibly including one or more fuel stops), and be able to explain your decision-making process for things like the planned course (if you don't fly in an absolute straight line) and your proposed altitude(s) and en-route waypoint(s).
1 - Usually you do the oral exam, then go fly. Sometimes you may do the oral one day and the flight portion another day - for example if the weather is lousy.
2 - This video is a little old, but a lot of it is still valid.
3 - You used to have to complete the flight plan the day of the exam, within 30 minutes, but that requirement has vanished from the PTS.
The Flight Exam
Every examiner conducts this a little differently - the tasks can be done in any order as long as they're all accomplished - but everyone I know has had the same basic sequence of events on their checkride.
After the oral you're going to get an update to your weather briefing (because you should), do a preflight inspection, get in the plane, and go fly your cross-country.
I've never met anyone who has actually flown the whole cross-country flight -- The examiner will typically have you fly through one or two waypoints to demonstrate that you can actually navigate, then you'll be told that something has gone awry and you need to divert ("The guy in the back is sick, take me to the closest airport before he hurls.").
When you've demonstrated your ability to navigate and divert, you'll usually cancel your flight plan (if you opened one) and break off to do the required air work.
At some point during your checkride the examiner will give you an engine failure, because aircraft engines are supremely unreliable whenever an examiner or CFI is in the right seat. You will be expected to pick a suitable landing point, establish a glide to that landing point, and run the "engine failure" checklist appropriate to your plane. The engine usually "miraculously restarts" at some point once the examiner is confident you would have been able to put the plane down on your intended landing spot.
The air-work consists of all the require flight maneuvers, such as steep turns, stalls, slips, and slow flight, the required ground reference maneuvers, and basic instrument maneuvers.
Once the air work is complete you'll return to the airport (or maybe to the airport you diverted to) for the dog-and-pony-show landings (one go-around -- usually called by the examiner with something exciting like "There's a moose on the runway! Go around!", one normal landing, one short-field landing over an FAA-Standard 50-foot giraffe, and one soft-field landing).
If you mess up and the examiner has to fail you they will tell you immediately after finishing the maneuver that you busted on. You usually have the option of continuing the test and completing the remaining tasks unless you did something that made the examiner fear for his or her life (if you're comfortable continuing this reduces the number of tasks you'll have to complete when you re-take the checkride).
Assuming you don't screw any thing up too badly, scare the examiner, or hit anything taxiing back to the ramp you're a private pilot - the examiner will fill out the appropriate paperwork, sign your logbook, and issue you your temporary certificate.
Your specific questions that I didn't answer above
How long does it take?
My checkride took about 3-4 hours -- about 1-2 hours for the logbook review & oral, just over an hour in the plane, and about an hour of "miscellaneous bits" (re-briefing the weather, the preflight, securing the plane after the practical portion of the test, completing the IACRA paperwork to make your new certificate/rating official).
How are emergencies created/tested?
The standard engine failure is usually created by pulling the throttle back. Your examiner may throw other curve balls at you (like handing you the foggles and saying "You just flew into a cloud, get us out of it."), or create random distractions ("dropping" their pen during climb-out appears to be a favorite from reading other people's checkride stories).
What's important isn't how the situations arise, but how you handle them. The examiner wants to see you fly the airplane safely, run the appropriate checklist(s), and handle the emergency in such a way that they're confident if it happened for real you'd be able to do the right thing.
Who makes sure the weather is suitable for flying?
You do! You are acting as Pilot In Command for your checkride, and you are expected to exercise sound judgment.
The examiner is not going to let you take off into a thunderstorm or gale-force winds (examiners have excellent self-preservation instincts. Most of them are or were flight instructors.), but if the examiner has to be the one to say "Yeah, I don't think we should fly in this weather" that's a guaranteed failure.
What if the checkride has to be cancelled for reasons not controlled by the student?
If you've already started (e.g. taken the oral, but can't do the flight portion because of weather, or the plane develops a mechanical problem) you'll receive a "notice of discontinuance" and reschedule the remainder of the exam.
Typically you can do this within 60 days, and you'll only have to do the portions of the exam you didn't do previously (though you can be re-tested on everything).
The same thing happens if you or the examiner have to cancel the exam for reasons not related to your aeronautical performance (that triple-breakfast-burrito on checkride day was NOT a good idea and you need to get back on the ground RIGHT NOW).
Probably a lot. I probably missed a lot too.
My checkride wasn't that long ago but I really don't remember much about it.
A common misconception is that the DE will bust you for one deviation or one wrong answer on the oral. That's simply not true. You must perform at an "acceptable level of competence," and only if you fail to perform at such a level will you be failed. The best way to avoid this is to acknowledge the deviation by saying something like "I'm low, correcting," and then correct. That way the DE knows you know what is happening in the plane, and that you are taking positive steps to correct it.
Also, don't think the DE can read your mind. Brief out loud everything that is happening in the plane: annunciate the checklist items, and say "takeoff checklist complete" when you're done; when you scan for traffic or make a clearing turn, say "clearing"; if you see a plane say something like "traffic, 4 o'clock low, opposite direction, no factor." The more you say, the more the DE knows how you think, and aeronautical decision-making is one of the most important skills a pilot must learn.
share|improve this answer
This is certainly very thorough. I liked the humor references. –  Farhan Jan 27 at 19:04
@Farhan some of those are direct quotes from the DE who did my checkride - those I remember :-) –  voretaq7 Jan 27 at 19:57
The "Before your checkride" portion has other things, of course. This question covers the requirements in more depth: What are the requirements to take the private pilot check ride? –  Lnafziger Jan 27 at 21:56
+1. If it were possible, I'd given an additional +1 for "Aircraft engines are supremely unreliable whenever an examiner or CFI is in the right seat." –  reirab Dec 18 at 19:02
they can be unreliable regardless of where she is sitting! –  rbp Dec 18 at 20:17
You will be examined in 3 ways, written, oral and practical. The checkride consists of only the oral and practical portions of the exams. The written is computer based and must have been completed with the 2 years preceding the checkride.
When you complete the written you will get a sheet that is stamped and embossed certifying your score and listing your deficient areas. You will present this to the designated examiner (DE) that conducts your checkride.
When your instructor recommends you for the checkride, he (or you) will coordinate with the DE and tell you to prepare a cross country flight plan (complete with winds/times/fuel burn for the day of the exam).
When you arrive at the checkride, the DE will being querying your knowledge about the airplane, its limitations, v-speeds, equipment, legality for VFR day/night flight, etc. He will also query your knowledge on flight planning, weather, airworthiness, navigation, regulations, etc. The topics of interest are all listed in the Practical Test Standards (PTS) area of operation I. These questions comprise the oral examination. This can take anywhere from 1 - 3 hours, depending on numerous factors (your performance, your deficiencies on the written, what checkride this is (initial vs addon vs instructor), etc.
Part of the airworthiness questioning will involve the aircraft logbooks and verifying the airplane is legal for the flight you are about to embark on.
For the practical part of the exam, the DE is going to observe and make notes and give the occasional command or question. He is not going to coach you. If he touches the controls, you will get the pink slip. From the go/no-go decision to the end of flight, you are the PIC and you must demonstrate the ability to perform as one.
You will preflight and perform some variety of takeoff at the DEs discretion and then proceed on your cross country flight. At some point along this flight you will find the need to divert and will be tested knowing how to calculate time/fuel burn to your new destination based on your present position, as well as properly turning to a heading that will get you there. Along the way you will do maneuvers. When you get there you will do some landings and takeoffs. On the way back home, you will do maneuvers. The list of maneuvers and how well you need to fly them are in the same PTS document linked above. This flight will probably be around 2.0 on the hobbes clock.
If at anytime you "bust" the checkride, the DE should tell you immediately and give you the option to go home or continue. It is in your interest to continue if your nerves haven't got the better of you as if you re-take the exam within 60 days you do not have to repeat successful items.
When you park the plane the DE will go inside while you do the post-flight and when you get inside he will either have a temporary certificate or a pink slip. If you get the certificate, you are a private pilot. If you get the pink slip, you get some more instruction and try again.
A great answer. Combining all of them gives a really good picture. –  Farhan Jan 27 at 19:05
You take the written exam before you take the checkride. When you pass the written, the proctor will give you a piece of paper that proves you passed, you need to show that to the DPE before the checkride.
In my case, when I called the DPE to schedule the checkride, he asked me to plan a cross country flight to an airport we both agreed upon. The examiner will review your planning and preflight preparation for the flight but you won't be landing at your destination. Depending on your examiner, he may ask you to divert or simply proceed with other requirements of the test.
That depends on the examiner. I believe an hour for the oral and two for the practical flight is common.
You should look through the Practical Test Standards book to understand what will be required of you. Expect a simulated engine failure, steep turns, power off and power on stalls, slow flight, etc.
You do, your examiner will be deferring to your judgement about all aspects of the flight. Weather, aircraft airworthiness, your comfort level, etc. He's looking to see if you'll be a safe pilot and make good decisions about flying. If you don't like the weather then reschedule the checkride.
Then you'll reschedule with the examiner. I've heard of people having to reschedule four or five times before they actually flew the practical test.
I know it's easier said than done but: relax! Treat the checkride less as a test and more as your first flight with a passenger. The examiner wants you to pass but they also want to make sure you'll be a safe pilot. Go up with your CFI as many times as needed to feel comfortable and then go up with another CFI in a mock checkride.
I like that you answered each question with your experience also. Thanks a bunch. –  Farhan Jan 27 at 19:07
Adding to the previous answers (very detailed, solid ones, I might add), it's good to ask around about the examiners in your area. They do differ in personality which can affect your experience. The best examiners make you comfortable enough to perform to the best of your ability. In my flying club (which licensed six new pilots this year of of a total of 30 members), most of us went with one DPE. One of the six, however, had some friction with that DPE and got his ticket with one of the other DPEs.
discard
