22
Do airplanes have any way to quantify the turbulence like if shakes are there or the some kind of air drift is happening every parameter of these have some units but do collectively there is any such unit which can quantify the turbulence?
  • 23
    $\begingroup$ Sick-bags per hour is a useful metric. $\endgroup$
    – Jon Story
    Jan 28, 2015 at 14:21
    $\begingroup$ Shrieks per minute? $\endgroup$
    – Simon
    Jan 28, 2015 at 17:15
  • 10
    $\begingroup$ I think you'll find that both sick-bags per hour and shrieks per minute have to be adjusted by the number of passengers, to sick-bags per passenger hour and shrieks per passenger minute. $\endgroup$ Jan 29, 2015 at 2:29
27
Turbulence can be quantitatively expressed as Eddy Dissipation Rate (EDR). EDR can be calculated from available onboard measurements, however it is not yet common for aircraft to have software to calculate the EDR.
Originally it was thought to have EDR reported over ADS-B, but it did not become a part of the current specifications. It might be in the next ADS-B version.
NASA Langley paper
World Meteorological Organization (WMO) presentation
Turbulence is described using the following qualitative descriptions [Source]:
Informally, you can use a g-meter to quantify turbulence, at least in the up-down direction, but I don't know of any particular values that equate to various types of turbulence
  • $\begingroup$ I will try to search again as soon as I have time, but IIRC Airbus defines "severe" anything above 0.5g $\endgroup$
    – Federico
    Jan 28, 2015 at 13:36
  • $\begingroup$ What... what does the push button do? I feel compelled to push it. $\endgroup$
    – corsiKa
    Jan 28, 2015 at 23:49
  • $\begingroup$ resets the + and - pointers back to 1G $\endgroup$
    – rbp
    Jan 28, 2015 at 23:57
  • $\begingroup$ ah, so the top and bottom dials are min and max (since last push on the push button). $\endgroup$ Jan 29, 2015 at 8:39
  • $\begingroup$ if by "top and bottom dials" you mean "top and bottom pointers" the answer is "sorta." The top is max positive G and the bottom is max negative G. min is going to be either 0G or +1G, depending on your frame of reference. $\endgroup$
    – rbp
    Jan 29, 2015 at 13:05
I think you are asking two questions in a single way. I understood that you would like to know firstly is there is a physical unit that could give you quantifyable information about airplane turbulence and, on top, you are asking if, having this unit, is possible to quantify turbulence in flight.
For the first one, you already have nice answer about them. You can quantify by using EDR or some other similar units.
To the second part of the question, can I actually in flight measure it?, the answer is more complicated. Is possible to measure the turbulence once the airplane is affected by it using its effect on the airplane.
However, to the question, can I measure the turbulence before airplane flies over it? that's more complicated, and there are some R&T projects trying to investigate LASER based detection both short range and long range (30km). There is an European project called DELICAT working on this topic.
